Aller au contenu principal
Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement
Ce dont vous avez besoin
  1. Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement, Remove the back cover: étape 1, image 1 de 3 Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement, Remove the back cover: étape 1, image 2 de 3 Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement, Remove the back cover: étape 1, image 3 de 3
    • Tools you will need is the Phillips #00 precision screwdriver, Plastic Opening Tools, and tweezers.
    • Insert plastic opening tool in the corner of device and slide along edges to separate adhesive.
    • Remove cover
  2. Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement: étape 2, image 1 de 3 Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement: étape 2, image 2 de 3 Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement: étape 2, image 3 de 3
    • Remove tape connecting front camera to motherboard and then disconnect the camera from the port.
    • Lift the camera from the right and simply wiggle out of the slot.
  3. Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement: étape 3, image 1 de 3 Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement: étape 3, image 2 de 3 Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement: étape 3, image 3 de 3
    • Disconnect the back camera from the port located in the upper right corner.
    • Lift up the camera cable using the tweezers.
    • Wiggle out camera from the slot.
2 autres ont terminé cette réparation.
Martin Luna
Membre depuis le 09/24/14
1 858 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 15-6, Remmell Fall 2014 Membre de l'équipe USF Tampa, Team 15-6, Remmell Fall 2014
USFT-REMMELL-F14S15G6
3 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 6
Total : 2,950
