Aller au contenu principal
Sony Xperia E3 Touch Screen Replacement
Ce dont vous avez besoin
Vidéo d'introduction
  1. Sony Xperia E3 Touch Screen Replacement, Turn of the Phone: étape 1, image 1 de 3 Sony Xperia E3 Touch Screen Replacement, Turn of the Phone: étape 1, image 2 de 3 Sony Xperia E3 Touch Screen Replacement, Turn of the Phone: étape 1, image 3 de 3
    • Turn off the device
    • Remove the SIM and the memory cards.
    • Remove 4x rubber corners.
    • There are 6x black screws Torx T4, remove them.
  2. Sony Xperia E3 Touch Screen Replacement, Rear Cover Removal: étape 2, image 1 de 3 Sony Xperia E3 Touch Screen Replacement, Rear Cover Removal: étape 2, image 2 de 3 Sony Xperia E3 Touch Screen Replacement, Rear Cover Removal: étape 2, image 3 de 3
    • Use a plastic tool and separate the rear bezel.
    • Be careful for the side buttons.
  3. Sony Xperia E3 Touch Screen Replacement, Touch Screen Flex Cable: étape 3, image 1 de 3 Sony Xperia E3 Touch Screen Replacement, Touch Screen Flex Cable: étape 3, image 2 de 3 Sony Xperia E3 Touch Screen Replacement, Touch Screen Flex Cable: étape 3, image 3 de 3
    • Disconnect the touch screen flex cable.
    • Disconnect the battery flex cable.
  4. Sony Xperia E3 Touch Screen Replacement: étape 4, image 1 de 3 Sony Xperia E3 Touch Screen Replacement: étape 4, image 2 de 3 Sony Xperia E3 Touch Screen Replacement: étape 4, image 3 de 3
    • With a hair dryer or heat gun warm the glass, at first for about 2-3 minutes.
    • Use a thin plastic tool, like a plastic pick and start the separation from the underside.
    • Do this very slow and periodically warm the glass!
    • At the beginning you have to separate the touch screen glass from the main frame.
  5. Sony Xperia E3 Touch Screen Replacement: étape 5, image 1 de 3 Sony Xperia E3 Touch Screen Replacement: étape 5, image 2 de 3 Sony Xperia E3 Touch Screen Replacement: étape 5, image 3 de 3
    Outil utilisé dans cette étape :
    Plastic Cards
    $2.99
    J'achète
    • Now continue with a plastic card.
    • AGAIN!!! Very slowly and periodically worm the glass.
    • The LCD is thin less than a millimeter!
    • Remove the touch screen.
  6. Sony Xperia E3 Touch Screen Replacement: étape 6, image 1 de 3 Sony Xperia E3 Touch Screen Replacement: étape 6, image 2 de 3 Sony Xperia E3 Touch Screen Replacement: étape 6, image 3 de 3
    • Now is time to test the phone.
    • If the LCD is OK you can order only a touch screen, if no, then you need display assembly - touch screen & LCD
    • With a plastic pick gently scrape the glue.
    • With a cloth and isopropyl alcohol clean the LCD.
    • Don't use a lot of alcohol. if the liquid passes behind the LCD, will appear spots that you can't remove.
  7. Sony Xperia E3 Touch Screen Replacement: étape 7, image 1 de 3 Sony Xperia E3 Touch Screen Replacement: étape 7, image 2 de 3 Sony Xperia E3 Touch Screen Replacement: étape 7, image 3 de 3
    • On the new touch screen or on the main frame put adhesive sticker 3mm.
    • Be careful not to cover the the places for the camera, sensor, earpiece, etc.
    • Lift the logic board a little bit, so that the touch screen flex cable can pass.
    • It's easier if you can order the touch screen together with adhesive which is cut off specifically for model.
  8. Sony Xperia E3 Touch Screen Replacement: étape 8, image 1 de 1
    • Reassemble the device.
    • That's all.
6 autres ont terminé cette réparation.
ZFix
Membre depuis le 12/09/13
191 674 Réputation
330 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
321 membres
1 507 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 6
Total : 7,991
