Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Sony Xperia J Camera Replacement
Ce dont vous avez besoin
  1. Sony Xperia J Camera  Replacement, External Features: étape 1, image 1 de 1
    • You will need a Torx T5 screwdriver, plastic opening tool, and a pincet for this operation.
    Demander à FixBot
    Ajouter un commentaire
  2. Sony Xperia J Camera  Replacement: étape 2, image 1 de 1
    • Find the little bracket on the bottom left of the phone (when looking at it upside down) and use the opening tool to pry off the back cover.
    Demander à FixBot
  3. Sony Xperia J Camera  Replacement: étape 3, image 1 de 1
    Outil utilisé dans cette étape :
    • Remove the silicone cover by squeezing it with the tweezers, there is not much pressure needed.
    Demander à FixBot
  4. Sony Xperia J Camera  Replacement: étape 4, image 1 de 3 Sony Xperia J Camera  Replacement: étape 4, image 2 de 3 Sony Xperia J Camera  Replacement: étape 4, image 3 de 3
    • Using the Torx T5 screwdriver remove the four 4.74mm screws.
    • Then remove the two 3.13mm screws
    • Lastly remove 5.90mm screw.
    Demander à FixBot
  5. Sony Xperia J Camera  Replacement: étape 5, image 1 de 3 Sony Xperia J Camera  Replacement: étape 5, image 2 de 3 Sony Xperia J Camera  Replacement: étape 5, image 3 de 3
    • Using the tweezers remove the black plate at the bottom of the phone. First insert the tweezers tip at the intersection between the black plate and phone, then just pull the plate up.
    • Repeat the same steps to remove the black plates located at the top left, and top right of the phone.
    Demander à FixBot
  6. Sony Xperia J Camera  Replacement: étape 6, image 1 de 1
    • After removing the top left black plate, you will find another 3.13mm screw. Just remove it by using the screwdriver.
    Demander à FixBot
  7. Sony Xperia J Camera  Replacement: étape 7, image 1 de 1
    • Place the plastic opening tool in-between the black external case of the phone and the silver case, then move it along the edges of the phone to detach the plates.
    Demander à FixBot
  8. Sony Xperia J Camera  Replacement, Removing Parts: étape 8, image 1 de 1
    • Using the tweezers remove the clip located at the top of the phone. It should snap right off without too much pressure.
    Demander à FixBot
  9. Sony Xperia J Camera  Replacement: étape 9, image 1 de 1
    • Then remove the sticky pad located at the left of the phone using he tweezers.
    Demander à FixBot
  10. Sony Xperia J Camera  Replacement, Removing Parts: étape 10, image 1 de 3 Sony Xperia J Camera  Replacement, Removing Parts: étape 10, image 2 de 3 Sony Xperia J Camera  Replacement, Removing Parts: étape 10, image 3 de 3
    • Using the tweezers lift the plate out of the clamps, from left to right.
    • Then remove the whole plate off the phone.
    • The plate might be a little sticky due to the glue used when assembling the phone.
    Demander à FixBot
  11. Sony Xperia J Camera  Replacement, Removing Parts: étape 11, image 1 de 1
    • Using the tweezers, slowly peel the white sticker off from the top right corner to the left bottom corner.
    Demander à FixBot
  12. Sony Xperia J Camera  Replacement, Removing Parts: étape 12, image 1 de 3 Sony Xperia J Camera  Replacement, Removing Parts: étape 12, image 2 de 3 Sony Xperia J Camera  Replacement, Removing Parts: étape 12, image 3 de 3
    • Once the sticker is off, unclip the clip on the top left side(below the camera). Then slide out the wide orange cable below the clip.
    • Then lift up the board carefully and remove the clip and cable on the back.
    Demander à FixBot
  13. Sony Xperia J Camera  Replacement, Removing the Camera: étape 13, image 1 de 2 Sony Xperia J Camera  Replacement, Removing the Camera: étape 13, image 2 de 2
    • Pop the camera out using your fingers, and then unclip it off the board using tweezers.
    Demander à FixBot
2 autres ont terminé cette réparation.
Arlind
Membre depuis le 01/21/15
899 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 4-3, Brown Winter 2015 Membre de l'équipe USF Tampa, Team 4-3, Brown Winter 2015
USFT-BROWN-W15S4G3
3 membres
6 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 4
30 derniers jours : 37
Total : 979
