Introduction
To complete this guide you will need to open the phone following the steps below to replace your keyboard module, using the required tools.
The battery should be removed before working on the phone internals.
Ce dont vous avez besoin
You will need a Torx T5 screwdriver, plastic opening tool, and a pincet for this operation.
Using the tweezers remove the black plate at the bottom of the phone. First insert the tweezers tip at the intersection between the black plate and phone, then just pull the plate up.
Repeat the same steps to remove the black plates located at the top left, and top right of the phone.
Remove adhesive black tape at the bottom left of the phone.
Then remove the clip by pulling it up and slide out the wide orange cable(seen in picture 2).
By using the tweezers, unclip the cable at the bottom right by pulling it up.
Finally, remove the keyboard module by pulling it up with the tweezers from right to left.
2 autres ont terminé cette réparation.
