Aller au contenu principal
Sony Xperia M4 Aqua Battery Replacement
Ce dont vous avez besoin
  1. Sony Xperia M4 Aqua Battery Replacement, Back Cover: étape 1, image 1 de 1
    • Place the phone face-down, and use a heat gun or hair dryer to evenly heat the back surface until to soften the adhesive.
  2. Sony Xperia M4 Aqua Battery Replacement: étape 2, image 1 de 1
    • Attach a suction cup to the back of the M4 Aqua by carefully pushing down on it near the top of the phone.
  3. Sony Xperia M4 Aqua Battery Replacement: étape 3, image 1 de 2 Sony Xperia M4 Aqua Battery Replacement: étape 3, image 2 de 2
    • While Pulling on the suction cup, slide a thin plastic spacer (guitar picks work well) between the back cover and the phone. Slide it around the edges to break the adhesive seal. Be careful, but don't be afraid to use some force. You should hear a sticky breaking sound.
  4. Sony Xperia M4 Aqua Battery Replacement: étape 4, image 1 de 1
    • Remove the back cover by pulling it from the chassis. it is flexible and can be bent, be careful.
  5. Sony Xperia M4 Aqua Battery Replacement, Battery: étape 5, image 1 de 1
    • Remove copper plated tape and any other securing adhesive with a nylon spudger. Remove carefully, as it has the potential or tear if too much force is used.
  6. Sony Xperia M4 Aqua Battery Replacement: étape 6, image 1 de 1
    • Unhook the battery connector carefully. It is possible to damage the battery if too much force is used.
  7. Sony Xperia M4 Aqua Battery Replacement: étape 7, image 1 de 1
    • Pry the battery from the phone with the nylon spudger. There is a small amount of adhesive underneath the battery, so a bit of force is required. The battery is malleable, so it is possible to dent the battery if too much force is applied in one spot.
  8. Sony Xperia M4 Aqua Battery Replacement: étape 8, image 1 de 1
    • Remove the battery once all of the adhesive is broken, and the connector is unplugged.
16 autres ont terminé cette réparation.
John Whitt
Membre depuis le 02/10/16
672 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 4-5, Lacy Spring 2016 Membre de l'équipe USF Tampa, Team 4-5, Lacy Spring 2016
USFT-LACY-S16S4G5
3 membres
8 tutoriels rédigés
11 commentaires
Hi... do you need to add some adhesive to reassemble it? Thanks.
Arief Yuha - Réponse
U actually buy another back end cover that has the adhesive....
Chase Bryan -
I found that I could just push it back on with the original glue and it reattached ok.
Dave Humm -
Das ist kein Xperia Z3
Das ist eine Anleitung vom M4 Aqua
Faruk - Réponse
Good video thanks.
I'm currently living in Thailand and they don't fix Sonys here in Krabi so I need to do it myself. Lazada has got the lcd and back cover for me, but they don't have a battery. I have a Sony Xperia aqua m4. Will the z3 battery fit...
Chase Bryan - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 14
30 derniers jours : 28
Total : 20,226
