Aller au contenu principal
Sony Xperia T2 Ultra Dual Audio Jack Replacement
Ce dont vous avez besoin
  1. Sony Xperia T2 Ultra Dual Audio Jack Replacement, Rear Case: étape 1, image 1 de 1
    • Using the spudger, pry open the back cover by starting alongside the edge of the back cover.
  2. Sony Xperia T2 Ultra Dual Audio Jack Replacement: étape 2, image 1 de 1
    • Once the part of the back cover has been opened up. Slide the spudger to pry completely detach the cover from the phone.
  3. Sony Xperia T2 Ultra Dual Audio Jack Replacement, Removing the internal cover: étape 3, image 1 de 1
    • Using the Phillips #00 Precision screwdriver, take out 8 silver screws (3.15mm) and 5 gold screws (3.9mm) for a total of all the screws attached to the flat plate. 3 of the gold screws are located at the top of the phone and the other 2 screws are located at the bottom of the phone.
  4. Sony Xperia T2 Ultra Dual Audio Jack Replacement: étape 4, image 1 de 2 Sony Xperia T2 Ultra Dual Audio Jack Replacement: étape 4, image 2 de 2
    • To remove the internal cover, use the plastic spudger tool and pry the cover from the phone as shown in the picture.
  5. Sony Xperia T2 Ultra Dual Audio Jack Replacement, Removing chip: étape 5, image 1 de 1
    • Using tweezer, locate the audio jack as shown and pull out the chip connected to the motherboard.
  6. Sony Xperia T2 Ultra Dual Audio Jack Replacement, Remove audio jack: étape 6, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Carefully remove the audio jack by using the tweezers and pull firmly straight out of the motherboard.
4 autres ont terminé cette réparation.
Christina Wojaczyk
Membre depuis le 09/26/14
1 450 Réputation
7 tutoriels rédigés
Équipe
USF Tampa, Team 13-3, Staggers Fall 2014 Membre de l'équipe USF Tampa, Team 13-3, Staggers Fall 2014
USFT-STAGGERS-F14S13G3
3 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 7
Total : 5,078
