Aller au contenu principal
Sony Xperia T2 Ultra Dual Rear Facing Camera Replacement
Ce dont vous avez besoin
  1. Sony Xperia T2 Ultra Dual Rear Facing Camera Replacement, Rear Case: étape 1, image 1 de 1
    • Using the spudger, pry open the back cover by starting alongside the edge of the back cover.
  2. Sony Xperia T2 Ultra Dual Rear Facing Camera Replacement: étape 2, image 1 de 1
    • Once the part of the back cover has been opened up. Slide the spudger to pry completely detach the cover from the phone.
  3. Sony Xperia T2 Ultra Dual Rear Facing Camera Replacement, Removing the internal cover: étape 3, image 1 de 1
    • Using the Phillips #00 Precision screwdriver, take out 8 silver screws (3.15mm) and 5 gold screws (3.9mm) for a total of all the screws attached to the flat plate. 3 of the gold screws are located at the top of the phone and the other 2 screws are located at the bottom of the phone.
  4. Sony Xperia T2 Ultra Dual Rear Facing Camera Replacement: étape 4, image 1 de 2 Sony Xperia T2 Ultra Dual Rear Facing Camera Replacement: étape 4, image 2 de 2
    • To remove the internal cover, use the plastic spudger tool and pry the cover from the phone as shown in the picture.
  5. Sony Xperia T2 Ultra Dual Rear Facing Camera Replacement, Removing Chip: étape 5, image 1 de 1
    • To take out the back facing camera, flip open the flap labelled ‘film’ to reveal the chip that connects to the motherboard.
  6. Sony Xperia T2 Ultra Dual Rear Facing Camera Replacement: étape 6, image 1 de 1
    • Use the tweezer, carefully pry open the chip for the back facing camera.
  7. Sony Xperia T2 Ultra Dual Rear Facing Camera Replacement, Remove back facing camera: étape 7, image 1 de 1
    • Then using the tweezer, carefully remove the back facing camera component.
5 autres ont terminé cette réparation.
Christina Wojaczyk
Membre depuis le 09/26/14
1 450 Réputation
7 tutoriels rédigés
Équipe
USF Tampa, Team 13-3, Staggers Fall 2014 Membre de l'équipe USF Tampa, Team 13-3, Staggers Fall 2014
USFT-STAGGERS-F14S13G3
3 membres
7 tutoriels rédigés
2 commentaires
Hlo hi sir Sony back cam of Sony Xperia t2 ultra
sai kiran - Réponse
Hi, Sir T2 Ultra dual Camera shows error - Unfortunately, Camera has stopped working. pls help . Thank yo
Alan Mathew - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 7
Total : 4,146
