Aller au contenu principal
Sony Xperia TL Battery Harness Replacement
Ce dont vous avez besoin
  1. Sony Xperia TL Battery Harness Replacement, Remove Top Plastic Section: étape 1, image 1 de 3 Sony Xperia TL Battery Harness Replacement, Remove Top Plastic Section: étape 1, image 2 de 3 Sony Xperia TL Battery Harness Replacement, Remove Top Plastic Section: étape 1, image 3 de 3
    • Use the plastic opening tool to pry the top plastic section off.
  2. Sony Xperia TL Battery Harness Replacement, Remove Bottom Plastic Section: étape 2, image 1 de 2 Sony Xperia TL Battery Harness Replacement, Remove Bottom Plastic Section: étape 2, image 2 de 2
    • Use the plastic opening tool to pry the bottom plastic section off.
  3. Sony Xperia TL Battery Harness Replacement, Unscrewing the Back Off: étape 3, image 1 de 3 Sony Xperia TL Battery Harness Replacement, Unscrewing the Back Off: étape 3, image 2 de 3 Sony Xperia TL Battery Harness Replacement, Unscrewing the Back Off: étape 3, image 3 de 3
    • Remove the four 5mm screws.
    • Use the plastic opening tool to pry off the back.
  4. Sony Xperia TL Battery Harness Replacement, Loud Speaker: étape 4, image 1 de 3 Sony Xperia TL Battery Harness Replacement, Loud Speaker: étape 4, image 2 de 3 Sony Xperia TL Battery Harness Replacement, Loud Speaker: étape 4, image 3 de 3
    • Use the plastic opening tool to remove the loud speaker module.
  5. Sony Xperia TL Battery Harness Replacement, Sony Xperia TL Auxiliary Cord Replacement: étape 5, image 1 de 2 Sony Xperia TL Battery Harness Replacement, Sony Xperia TL Auxiliary Cord Replacement: étape 5, image 2 de 2
    • Use the plastic opening tool to unlatch the cord's ends off the motherboard and loud speaker module. The cord can be located on the right side of the phone.
  6. Sony Xperia TL Battery Harness Replacement, Battery Harness: étape 6, image 1 de 3 Sony Xperia TL Battery Harness Replacement, Battery Harness: étape 6, image 2 de 3 Sony Xperia TL Battery Harness Replacement, Battery Harness: étape 6, image 3 de 3
    • Unhook the 2 connections between the harness and phone shell.
    • Using the plastic opening tool, pry the harness up and remove it.
    • There is an adhesive on the bottom half of the battery harness.
  7. Sony Xperia TL Battery Harness Replacement: étape 7, image 1 de 1
    • The final step is taking the entire harness off of the phone.
Adam Giniger
Membre depuis le 09/22/14
1 303 Réputation
8 tutoriels rédigés
Équipe
USF Tampa, Team 4-4, Brown Fall 2014 Membre de l'équipe USF Tampa, Team 4-4, Brown Fall 2014
USFT-BROWN-F14S4G4
3 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 2
30 derniers jours : 15
Total : 339
