Introduction
Removing this part is hard for the first time because the manufacturer used adhesive to keep it in place.
Pièces
Aucune pièce nécessaire.
Use the plastic opening tool to pry the top plastic section off.
  • Use the plastic opening tool to pry the top plastic section off.
Ajouter un commentaire
Use the plastic opening tool to pry the bottom plastic section off.
  • Use the plastic opening tool to pry the bottom plastic section off.
  • Remove the four 5mm screws.
  • Use the plastic opening tool to pry off the back.
  • Use the plastic opening tool to detach the ribbon running across the battery.
  • Use the plastic opening tool to detach the ribbon connecting the battery to the motherboard.
3 autre(s) ont terminé cette réparation.
Adam Giniger
Membre depuis le 22/09/2014
1 184 Réputation
8 tutoriels rédigés
Équipe
USF Tampa, Team 4-4, Brown Fall 2014 Membre de l'équipe USF Tampa, Team 4-4, Brown Fall 2014
USFT-BROWN-F14S4G4
3 membres
10 tutoriels rédigés
Is it necessary to back up the phone before replacing the battery, or will the settings be preserved?
r3woods - Réponse
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 17
Total : 1,558
