Aller au contenu principal
Sony Xperia U Motherboard Replacement
Ce dont vous avez besoin
  1. Sony Xperia U Motherboard Replacement, Battery: étape 1, image 1 de 1
    • Set the phone screen down on a clean flat, surface.
    • Insert the plastic opening tool into the groove located between the body of the phone, and the back plate protecting the battery.
    • Open the back of the device by prying around the sides of the back panel using the plastic opening tool.
  2. Sony Xperia U Motherboard Replacement: étape 2, image 1 de 1
    • Insert the plastic opening tool in between the battery and the phone body.
    • Pry up on the side of battery, and remove it.
  3. Sony Xperia U Motherboard Replacement, Motherboard: étape 3, image 1 de 1
    • Remove the bottom cover of the phone using the plastic opening tool.
  4. Sony Xperia U Motherboard Replacement: étape 4, image 1 de 1
    • Remove the five 5.47mm and one 5.18mm Torx head screws using a Phillips #0 screwdriver.
  5. Sony Xperia U Motherboard Replacement: étape 5, image 1 de 1
    • Carefully remove the back cover using the plastic opening tool.
  6. Sony Xperia U Motherboard Replacement: étape 6, image 1 de 1
    • Pry up on the right side of the motherboard using the plastic opening tool.
  7. Sony Xperia U Motherboard Replacement: étape 7, image 1 de 1
    • Carefully detach the flex cable using a pair of tweezers.
3 autres ont terminé cette réparation.
Bader
Membre depuis le 10/07/14
545 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 7-2, Leahy Fall 2014 Membre de l'équipe USF Tampa, Team 7-2, Leahy Fall 2014
USFT-LEAHY-F14S7G2
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 4
Total : 2,848
