Aller au contenu principal
Sony Xperia U Speaker Replacement
Ce dont vous avez besoin
  1. Sony Xperia U Speaker Replacement, Battery: étape 1, image 1 de 1
    • Set the phone screen down on a clean flat, surface.
    • Insert the plastic opening tool into the groove located between the body of the phone, and the back plate protecting the battery.
    • Open the back of the device by prying around the sides of the back panel using the plastic opening tool.
  2. Sony Xperia U Speaker Replacement: étape 2, image 1 de 1
    • Insert the plastic opening tool in between the battery and the phone body.
    • Pry up on the side of battery, and remove it.
  3. Sony Xperia U Speaker Replacement, Headphone Jack: étape 3, image 1 de 1
    • Insert the plastic opening tool in between the white plastic cover, and the body of the phone.
    • Pop the plastic cover off. To do this, gently push forward on the plastic opening tool while it is in between the cover and the phone.
  4. Sony Xperia U Speaker Replacement: étape 4, image 1 de 1
    • Remove the six size 0 Phillips screws.
  5. Sony Xperia U Speaker Replacement: étape 5, image 1 de 1
    • Insert the plastic opening tool in between the body of the phone and the thin plastic back cover.
    • Lift the black back cover off of the body with the plastic tool.
  6. Sony Xperia U Speaker Replacement: étape 6, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Locate the earphone jack on the top left of the black plastic back cover.
    • Use the tweezers to pinch the earphone jack and remove it from the back cover.
  7. Sony Xperia U Speaker Replacement, Speaker: étape 7, image 1 de 1
    J'achète
    • Using the tweezers, remove the loudspeaker module by firmly grasping it on one side, then slowly and carefully pulling the module in an upward direction.
3 autres ont terminé cette réparation.
Bader
Membre depuis le 10/07/14
545 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 7-2, Leahy Fall 2014 Membre de l'équipe USF Tampa, Team 7-2, Leahy Fall 2014
USFT-LEAHY-F14S7G2
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 2
30 derniers jours : 7
Total : 932
