Aller au contenu principal
Sony Xperia XA Motherboard Replacement
Ce dont vous avez besoin
  1. Sony Xperia XA Motherboard Replacement, Back Cover: étape 1, image 1 de 1
    • Apply heat on the back surface of the phone.
    • Continue to heat the device as needed throughout the replacement process.
    • The device can get very hot, so be careful when handling it.
  2. Sony Xperia XA Motherboard Replacement: étape 2, image 1 de 1
    • Stick the small suction cup on the bottom half of the back surface of the phone.
  3. Sony Xperia XA Motherboard Replacement: étape 3, image 1 de 3 Sony Xperia XA Motherboard Replacement: étape 3, image 2 de 3 Sony Xperia XA Motherboard Replacement: étape 3, image 3 de 3
    • With the bottom of the device facing you, lift up on the suction cup handle.
    • Use the plastic opening tool around all sides to pry off the back cover.
  4. Sony Xperia XA Motherboard Replacement: étape 4, image 1 de 3 Sony Xperia XA Motherboard Replacement: étape 4, image 2 de 3 Sony Xperia XA Motherboard Replacement: étape 4, image 3 de 3
    • Pull the back of the phone case away from the device.
    • You will hear popping sounds of glue being ripped from the phone.
    • You will hear the sound of the back unlatching from the device.
    • You will need to apply adhesive or glue along the device to have maximum seal in reassembly.
    • RAF antenna may be attached to the back cover upon removal.
  5. Sony Xperia XA Motherboard Replacement: étape 5, image 1 de 1
    • Apply heat to the copper RAF antenna.
    • This step and the following step only apply if the RAF antenna does not come off when taking the back cover off.
  6. Sony Xperia XA Motherboard Replacement: étape 6, image 1 de 1
    • Peel back the RAF antenna.
  7. Sony Xperia XA Motherboard Replacement, Motherboard: étape 7, image 1 de 2 Sony Xperia XA Motherboard Replacement, Motherboard: étape 7, image 2 de 2
    • Pry up the copper connector next to the battery with the plastic opening tool.
  8. Sony Xperia XA Motherboard Replacement: étape 8, image 1 de 2 Sony Xperia XA Motherboard Replacement: étape 8, image 2 de 2
    • Remove the five black 4mm screws with a Phillips #00 Screwdriver.
  9. Sony Xperia XA Motherboard Replacement: étape 9, image 1 de 3 Sony Xperia XA Motherboard Replacement: étape 9, image 2 de 3 Sony Xperia XA Motherboard Replacement: étape 9, image 3 de 3
    • Pry up the black camera case with the plastic opening tool and then remove the case.
  10. Sony Xperia XA Motherboard Replacement: étape 10, image 1 de 2 Sony Xperia XA Motherboard Replacement: étape 10, image 2 de 2
    • Pop off the small connector on the right side of the motherboard with the plastic opening tool.
  11. Sony Xperia XA Motherboard Replacement: étape 11, image 1 de 2 Sony Xperia XA Motherboard Replacement: étape 11, image 2 de 2
    • Use the spudger to take off the connector in the top right of the motherboard.
  12. Sony Xperia XA Motherboard Replacement: étape 12, image 1 de 3 Sony Xperia XA Motherboard Replacement: étape 12, image 2 de 3 Sony Xperia XA Motherboard Replacement: étape 12, image 3 de 3
    • Use the flat end of the spudger to peel up the copper tab to the right of the back camera.
    • Peel back the tab past the connector.
    • Tab is stuck with adhesive.
  13. Sony Xperia XA Motherboard Replacement: étape 13, image 1 de 3 Sony Xperia XA Motherboard Replacement: étape 13, image 2 de 3 Sony Xperia XA Motherboard Replacement: étape 13, image 3 de 3
    • Pry up the camera's connector to the motherboard with the nylon spudger.
  14. Sony Xperia XA Motherboard Replacement: étape 14, image 1 de 2 Sony Xperia XA Motherboard Replacement: étape 14, image 2 de 2
    • Use the spudger to loosen the black connector from the top right of the motherboard.
  15. Sony Xperia XA Motherboard Replacement: étape 15, image 1 de 3 Sony Xperia XA Motherboard Replacement: étape 15, image 2 de 3 Sony Xperia XA Motherboard Replacement: étape 15, image 3 de 3
    • Pull out the square shaped connector using tweezers.
  16. Sony Xperia XA Motherboard Replacement: étape 16, image 1 de 2 Sony Xperia XA Motherboard Replacement: étape 16, image 2 de 2
    • Use the spudger to detach the three copper connectors on the bottom area of the motherboard.
  17. Sony Xperia XA Motherboard Replacement: étape 17, image 1 de 3 Sony Xperia XA Motherboard Replacement: étape 17, image 2 de 3 Sony Xperia XA Motherboard Replacement: étape 17, image 3 de 3
    • Use the spudger to separate the motherboard from the frame.
    • Pull out the motherboard using your fingers.
2 autres ont terminé cette réparation.
Anthony Hernandez
Membre depuis le 04/18/18
730 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team S17-G2, Livingston Spring 2018 Membre de l'équipe Cal Poly, Team S17-G2, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G2
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 13
Total : 2,362
