Aller au contenu principal
Sony Xperia XA1 Ultra Back Assembly Replacement
Ce dont vous avez besoin
  1. Sony Xperia XA1 Ultra Back Assembly Replacement, Back Assembly: étape 1, image 1 de 2 Sony Xperia XA1 Ultra Back Assembly Replacement, Back Assembly: étape 1, image 2 de 2
    • Wedge your finger under the bottom ridge of the SD card insert.
    • Pull outwards with your fingers to remove the SD card from the left side of device.
  2. Sony Xperia XA1 Ultra Back Assembly Replacement: étape 2, image 1 de 1
    • Use a hair dryer to heat each corner of the phone.
    • Alternate heating each corner for a minute to loosen the adhesive binding the back cover to the phone.
    • Don't heat one area for too long; the phone may get damaged from overheating.
  3. Sony Xperia XA1 Ultra Back Assembly Replacement: étape 3, image 1 de 1
    • Press a suction cup on a heated corner of the device.
    • Hold the phone down and gently lift the suction cup to create a small gap.
    • You may hear crunching or popping sounds when you lift up the back cover.
  4. Sony Xperia XA1 Ultra Back Assembly Replacement: étape 4, image 1 de 1
    Outil utilisé dans cette étape :
    Plastic Cards
    $2.99
    • Insert your iFixit Opening Tool in the small gap between your phone and the back cover.
    • Lift up on the iFixit Opening Tool and insert your plastic card in the small gap between your phone and the back cover.
  5. Sony Xperia XA1 Ultra Back Assembly Replacement: étape 5, image 1 de 1
    • Slide your plastic card along the side of your phone to loosen the adhesive.
    • Move the card along the sides of the phone to lift all of the corners.
  6. Sony Xperia XA1 Ultra Back Assembly Replacement: étape 6, image 1 de 1
    • Lift up the back cover by lifting up the sides of the phone with your hand.
    • Apply a new strip of adhesive for reassembly.
2 autres ont terminé cette réparation.
Jacob Jung
Membre depuis le 04/18/18
1 429 Réputation
9 tutoriels rédigés
Équipe
Cal Poly, Team S16-G3, Livingston Spring 2018 Membre de l'équipe Cal Poly, Team S16-G3, Livingston Spring 2018
CPSU-LIVINGSTON-S18S16G3
4 membres
9 tutoriels rédigés
Un commentaire
What kind of adhesive should be used when reassembling the phone?
Nicholas Bates - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 28
Total : 3,296
