Aller au contenu principal
Sony Xperia XA1 Ultra Motherboard Replacement
Ce dont vous avez besoin
  1. Sony Xperia XA1 Ultra Motherboard Replacement, Back Assembly: étape 1, image 1 de 2 Sony Xperia XA1 Ultra Motherboard Replacement, Back Assembly: étape 1, image 2 de 2
    • Wedge your finger under the bottom ridge of the SD card insert.
    • Pull outwards with your fingers to remove the SD card from the left side of device.
  2. Sony Xperia XA1 Ultra Motherboard Replacement: étape 2, image 1 de 1
    • Use a hair dryer to heat each corner of the phone.
    • Alternate heating each corner for a minute to loosen the adhesive binding the back cover to the phone.
    • Don't heat one area for too long; the phone may get damaged from overheating.
  3. Sony Xperia XA1 Ultra Motherboard Replacement: étape 3, image 1 de 1
    • Press a suction cup on a heated corner of the device.
    • Hold the phone down and gently lift the suction cup to create a small gap.
    • You may hear crunching or popping sounds when you lift up the back cover.
  4. Sony Xperia XA1 Ultra Motherboard Replacement: étape 4, image 1 de 1
    Outil utilisé dans cette étape :
    Plastic Cards
    $2.99
    • Insert your iFixit Opening Tool in the small gap between your phone and the back cover.
    • Lift up on the iFixit Opening Tool and insert your plastic card in the small gap between your phone and the back cover.
  5. Sony Xperia XA1 Ultra Motherboard Replacement: étape 5, image 1 de 1
    • Slide your plastic card along the side of your phone to loosen the adhesive.
    • Move the card along the sides of the phone to lift all of the corners.
  6. Sony Xperia XA1 Ultra Motherboard Replacement: étape 6, image 1 de 1
    • Lift up the back cover by lifting up the sides of the phone with your hand.
    • Apply a new strip of adhesive for reassembly.
  7. Sony Xperia XA1 Ultra Motherboard Replacement, Battery: étape 7, image 1 de 3 Sony Xperia XA1 Ultra Motherboard Replacement, Battery: étape 7, image 2 de 3 Sony Xperia XA1 Ultra Motherboard Replacement, Battery: étape 7, image 3 de 3
    • Peel off the two pieces of black tape covering the battery with your hands.
  8. Sony Xperia XA1 Ultra Motherboard Replacement: étape 8, image 1 de 2 Sony Xperia XA1 Ultra Motherboard Replacement: étape 8, image 2 de 2
    • Use the iFixit Opening Tool to remove the flexible orange strip which connects the battery to the motherboard.
  9. Sony Xperia XA1 Ultra Motherboard Replacement: étape 9, image 1 de 3 Sony Xperia XA1 Ultra Motherboard Replacement: étape 9, image 2 de 3 Sony Xperia XA1 Ultra Motherboard Replacement: étape 9, image 3 de 3
    • Wedge the iFixit Opening Tool underneath the battery.
    • Remove the battery by pulling up on the iFixit Opening Tool.
  10. Sony Xperia XA1 Ultra Motherboard Replacement, Antenna Module: étape 10, image 1 de 2 Sony Xperia XA1 Ultra Motherboard Replacement, Antenna Module: étape 10, image 2 de 2
    • Remove the four 4mm T5 screws on the top of the black panel securing the antenna module to the device.
  11. Sony Xperia XA1 Ultra Motherboard Replacement: étape 11, image 1 de 2 Sony Xperia XA1 Ultra Motherboard Replacement: étape 11, image 2 de 2
    • Insert your iFixit Opening Tool underneath the antenna module.
    • Lift up gently with the iFixit Opening Tool to remove the antenna module.
    • The antenna module may be difficult to remove.
  12. Sony Xperia XA1 Ultra Motherboard Replacement, Front Camera: étape 12, image 1 de 2 Sony Xperia XA1 Ultra Motherboard Replacement, Front Camera: étape 12, image 2 de 2
    • Insert your iFixit Opening Tool underneath the front camera and gently lift up.
    • Remove the front camera by lifting the front camera up with your hands.
  13. Sony Xperia XA1 Ultra Motherboard Replacement, Headphone Jack: étape 13, image 1 de 2 Sony Xperia XA1 Ultra Motherboard Replacement, Headphone Jack: étape 13, image 2 de 2
    • Remove the 4mm T5 screw connecting the headphone jack to the panel.
  14. Sony Xperia XA1 Ultra Motherboard Replacement: étape 14, image 1 de 2 Sony Xperia XA1 Ultra Motherboard Replacement: étape 14, image 2 de 2
    • Use your iFixit Opening Tool to lift and disconnect the headphone jack connector piece.
    • The small black piece connected to the headphone jack that is holding the single screw in place has broken off in the device shown.
  15. Sony Xperia XA1 Ultra Motherboard Replacement, Back Camera: étape 15, image 1 de 2 Sony Xperia XA1 Ultra Motherboard Replacement, Back Camera: étape 15, image 2 de 2
    • Insert your iFixit Opening Tool between the back camera and the motherboard and gently lift up.
    • Lift up with the iFixit Opening Tool until the back camera is removed from the device.
  16. Sony Xperia XA1 Ultra Motherboard Replacement, Motherboard: étape 16, image 1 de 2 Sony Xperia XA1 Ultra Motherboard Replacement, Motherboard: étape 16, image 2 de 2
    • Remove the two 4mm T5 screws connecting the motherboard to the device.
  17. Sony Xperia XA1 Ultra Motherboard Replacement: étape 17, image 1 de 3 Sony Xperia XA1 Ultra Motherboard Replacement: étape 17, image 2 de 3 Sony Xperia XA1 Ultra Motherboard Replacement: étape 17, image 3 de 3
    • Use your flat head tweezers to remove the black wire connected to the motherboard.
    • Use your flat head tweezers to remove the white wire connected to the motherboard.
    • There are only two wires connected to the motherboard.
  18. Sony Xperia XA1 Ultra Motherboard Replacement: étape 18, image 1 de 3 Sony Xperia XA1 Ultra Motherboard Replacement: étape 18, image 2 de 3 Sony Xperia XA1 Ultra Motherboard Replacement: étape 18, image 3 de 3
    • Use your iFixit Opening Tool to remove the main flex (the middle orange tab) from the motherboard.
    • Use your iFixit Opening Tool to remove the power button flex (the left orange tab) from the motherboard.
  19. Sony Xperia XA1 Ultra Motherboard Replacement: étape 19, image 1 de 2 Sony Xperia XA1 Ultra Motherboard Replacement: étape 19, image 2 de 2
    • Wedge your iFixit opening tool under the motherboard.
    • Lift up with your iFixit Opening Tool to lift the motherboard from the device.
2 autres ont terminé cette réparation.
Jacob Jung
Membre depuis le 04/18/18
1 429 Réputation
9 tutoriels rédigés
Équipe
Cal Poly, Team S16-G3, Livingston Spring 2018 Membre de l'équipe Cal Poly, Team S16-G3, Livingston Spring 2018
CPSU-LIVINGSTON-S18S16G3
4 membres
9 tutoriels rédigés
3 commentaires
where can i place an order for the motherboard
obivinn - Réponse
yeah. Where??
Timothy Tomon -
I have sony xa1 ultra and one of Nfc pins on motherboard fell off. Does anyone know where this signal goes so I could solder it?
Fears - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 48
Total : 4,443
