Introduction
In this video, i will show you how to replacement battery for Sony xperia xz1 compact.
Ce dont vous avez besoin
Instructions vidéo
6 autres ont terminé cette réparation.
4 commentaires de tutoriel
This is a very good instruction for a job that has lots of work to do. Kudos for the author.
It took me about 2 hours to get my phone ready to use.
The hardest part was to remove the battery from the motherboard without braking anything.
Harri Vähätalo - Réponse Partager
Réalisé en +/- 2h. Bien expliqué, merci !
Patrick JOACHIM - Réponse Partager
Useful tip from @kire456 on youtube: "A tip for others: the glue strip along the edges of the screen is only 1.5mm wide, and behind the LCD screen is a very fragile reflective sheet of foil that is easily damaged. So make sure not to wedge your plastic card in deeper than you need to, when you are removing the LCD screen. I did, and damaged the reflective foil."
tony - Réponse Partager
thank God for this working AKA Dvidan gold 24
Anezi chukwuemeka - Réponse Partager
