Introduction
If your phone is running slow or looses charge very quickly, your battery might be the reason and it may be time for a replacement. This guide will instruct you on replacing the battery of your Sony Xperia XZ2.
Before removing the battery, you will have to remove the front screen. You will need a spudger and a Phillips #00 screwdriver head.
Ce dont vous avez besoin
Weaken the glue that is keeping the screen in place by heating up the edges of the phone with a hair dryer or heat gun.
Outil utilisé dans cette étape :Tweezers$3.99
Remove the bracket covering the connector by grabbing one side of the bracket with angled tweezers and gently pulling it off.
Take out the twelve 3.5mm screws using the Phillips #00 screwdriver.
Remove the one 3 mm Phillips #00 screws.
Remove the two 1mm Phillips #00 screws.
3 autres ont terminé cette réparation.
