Introduction
If the front camera on your Sony Xperia XZ2 is no longer working, it may need to be replaced. To replace the front camera use this guide. For this guide you will need a hair dryer, opening picks, angled tweezers, a spudger, and a Phillips #00 screwdriver.
Replacing the front camera requires removal of the LCD screen.
Ce dont vous avez besoin
Weaken the glue that is keeping the screen in place by heating up the edges of the phone with a hair dryer or heat gun.
Take out the twelve 3.5mm screws using the Phillips #00 screwdriver.
Remove the one 3 mm Phillips #00 screws.
Remove the two 1mm Phillips #00 screws.
