Aller au contenu principal
Sony Xperia Z Display Assembly Replacement
Ce dont vous avez besoin
Vidéo d'introduction
  1. Sony Xperia Z Display Assembly Replacement, Touch Screen Glass Digitizer & LCD Display: étape 1, image 1 de 3 Sony Xperia Z Display Assembly Replacement, Touch Screen Glass Digitizer & LCD Display: étape 1, image 2 de 3 Sony Xperia Z Display Assembly Replacement, Touch Screen Glass Digitizer & LCD Display: étape 1, image 3 de 3
    • Warm the Battery cover before disassemble it.
  2. Sony Xperia Z Display Assembly Replacement: étape 2, image 1 de 3 Sony Xperia Z Display Assembly Replacement: étape 2, image 2 de 3 Sony Xperia Z Display Assembly Replacement: étape 2, image 3 de 3
    • 'Carefully' warm the battery too
  3. Sony Xperia Z Display Assembly Replacement: étape 3, image 1 de 3 Sony Xperia Z Display Assembly Replacement: étape 3, image 2 de 3 Sony Xperia Z Display Assembly Replacement: étape 3, image 3 de 3
    • Unscrew 4x screws and disconnect 3x flex cables in case to free the mother board.
  4. Sony Xperia Z Display Assembly Replacement: étape 4, image 1 de 3 Sony Xperia Z Display Assembly Replacement: étape 4, image 2 de 3 Sony Xperia Z Display Assembly Replacement: étape 4, image 3 de 3
    • This are: main Camera, front Camera and antenna wire Flex cable.
    • Now we can remove the Motherboard.
  5. Sony Xperia Z Display Assembly Replacement: étape 5, image 1 de 3 Sony Xperia Z Display Assembly Replacement: étape 5, image 2 de 3 Sony Xperia Z Display Assembly Replacement: étape 5, image 3 de 3
    • The Headphone connector and the Ringer / Cover / Signal Antenna module.
  6. Sony Xperia Z Display Assembly Replacement: étape 6, image 1 de 3 Sony Xperia Z Display Assembly Replacement: étape 6, image 2 de 3 Sony Xperia Z Display Assembly Replacement: étape 6, image 3 de 3
    • Disconnect the LCD light flex cable by lifting up the black plastic and removing the flex cable from the right side and we are ready to go.
  7. Sony Xperia Z Display Assembly Replacement: étape 7, image 1 de 3 Sony Xperia Z Display Assembly Replacement: étape 7, image 2 de 3 Sony Xperia Z Display Assembly Replacement: étape 7, image 3 de 3
    • Warm the Touch screen before you start to disassemble it.
  8. Sony Xperia Z Display Assembly Replacement: étape 8, image 1 de 3 Sony Xperia Z Display Assembly Replacement: étape 8, image 2 de 3 Sony Xperia Z Display Assembly Replacement: étape 8, image 3 de 3
    • Let's assemble the new spare part.
  9. Sony Xperia Z Display Assembly Replacement: étape 9, image 1 de 3 Sony Xperia Z Display Assembly Replacement: étape 9, image 2 de 3 Sony Xperia Z Display Assembly Replacement: étape 9, image 3 de 3
76 autres ont terminé cette réparation.
ZFix
Membre depuis le 12/09/13
187 961 Réputation
330 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
311 membres
1 194 tutoriels rédigés
54 commentaires
Same procedure with Sony Xperia Z2?
Fredrik - Réponse
How do you warm it? With what and what temperature ?
Jeroen - Réponse
with a hairdryer for like 3 min on high
Peter Tembo -
With hair dryer.
ZFix - Réponse
Same procedure with Sony Xperia Z1? Where do i get the screen parts?
chrgro - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 7
7 derniers jours : 24
30 derniers jours : 58
Total : 237,291
