Introduction
If your screen went black while using the front camera and performing a hard reset and software update did not fix this problem, replacing the front camera may solve these problems.
Ce dont vous avez besoin
Use the small suction cup to lift the back panel:
Press the small suction cup on to the middle of the back panel.
While holding the Sony Xperia Z ultra down with your left hand, slightly pull the small suction cup upwards to create a small opening between the back panel and the front panel.
While continuing to pull the small suction cup upwards, insert the spudger in the small opening.
Pry the front panel downwards with the spudger while continuing to pull the small suction cup upwards.
Pry the connection upwards from the motherboard with the spudger to reveal the front facing camera.
4 autres ont terminé cette réparation.
