Introduction
If your Sony Xperia Z1s (model C6916) does not charge, your charging port might need replacement.
The charging port is the connection between your charger and battery. A faulty charging port might cause your phone to not charge or charge very slowly.
This guide requires that you have the necessary equipment and knowledge of desoldering and soldering connections. If you want to learn the skills needed for soldering, please refer to the following guide: How To Solder and Desolder Connections.
Before beginning this guide, turn off your phone completely and remove it from any external power source.
Ce dont vous avez besoin
Insert the opening pick in the crease between the rear cover and the body of the phone.
Pry along the edge to lift and remove the back cover.
Use the opening pick to pry off the camera flex cable.
Continue to lift the flex cable upward until the camera pops out.
Use the soldering iron to desolder and loosen the charging port from the motherboard.
