Introduction
How to disassemble the phone and replace the Diasplay Assemblay (LCD Display & Touchscreen module).
Please SUBSCRIBE to my channel ツ
Vidéo d'introduction
Switch off the phone.
  • Switch off the phone.
  • If you can't switch it off, you can use the OFF button near to the SIM card Tray.
  • Warm the Back Cover. You can use a hairdryer.
  • Be careful, the Back Cover is plastic.
Ajouter un commentaire
Use a small suction cup and plastic tools for separating the Rear panel.
  • Use a small suction cup and plastic tools for separating the Rear panel.
  • There is Adhesive tape on the edges of the phone and some between the Battery and the Back Cover, as well. I found a small tab to pull just inside the top of the cover that removed the adhesive and released the back panel from the battery. Its that same style adhesive strip as used in the Iphone 5/5c/5s.
  • Before installing the new cover, you must clean the phone from the old adhesive tape and install a new one (if your spare part has come without double sided adhesive tape).
  • Please SUBSCRIBE to my channel ツ
Should include the information about the NFC antenna.
Sounds like a dealbreaker for some people.
Diogo Pinheiro - Réponse
What about it?
Makos - Réponse
Did you use the custom adhesive or the 3M double sided tape?
kelvinteohbc - Réponse
  • Remove the Loudspeaker metal bracket.
  • Remove the two Phillips screws that hold Loudspeaker/Vibromotor module.
  • Disconnect the Coaxial Antenna cable.
  • With the sharp end of the plastic tool carefully subtract the module from the phone housing.
  • The Loud Speaker has some adhesive holding it to the chassis so a little heat on the front will help.
  • Disconnect the Touchscreen flex cables.
  • Disconnect the LCD Display flex cable.
  • You can embed the Loudspeaker module to the phone housing with masking tape. This will prevent the ribbon from breaking.
  • Use a transparent packaging tape and stick it on top of the glass. This will help you remove the broken glass later.
  • Preheat the Display.
  • Use a cutter to make a room for a plastic tool.
  • Continue separating the display from the frame by using plastic opening tools.
  • Clean the frame from the remains of tape.
  • Now it's time to test the new spare part.
  • Use a high quality adhesive sticker for the model.
  • This will stick the display to the frame harder and it will save the waterproof ability of your phone.
Did it! It's pretty easy.
Freek Wennekers - Réponse
56 autre(s) ont terminé cette réparation.
ZFix
Membre depuis le 09/12/2013
156 577 Réputation
304 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
277 membres
748 tutoriels rédigés
22 commentaires
Worked! I very much recommend watching the video as well as read the manual to get a complete picture. My total time spent was multiple hours, but largely because it's the first time I'm doing a repair that involves so much glue. Gained a few gray hairs there.
Two stumbles:
I missed the line "The load Speaker has some adhesive holding it to the chassis so a little heat on the front will help.", which cost me a lot of time and worry as I was trying to force the speaker assembly out. Eventually got it out, and it's fine. Ribbon cables will be the death of me some day.
I did not keep the little bit of tape on the display ribbon safe and clean and ended up not using it at all. The written manual doesn't show its reuse, the video does.
Also: getting (almost) all of the glue goop off the back was a tragedy.
Minic - Réponse
so cool, is simple.
danielassro - Réponse
She lives, very nice guide! :D
Jroen - Réponse
My Xperia Z2 touch screen is fixed at a phone repaircenter. I dont know what they do but since that day it looks like my touchscreen living his own life. Especially if i type some text with the stock keyboard. Its very frustrating and my question is.....can i do something about it myself?
Sorry for my bad English btw
Anita van Geel - Réponse
Before gluing the screen to work well sensors and all that, you need to put some black tape on the camera or sensors?
Is it and seen online tutorials or is not necessary
Hector Gonzalez - Réponse
I did not glue and it was fine.
Tech Sponge -
Hi,
i need to change my LCD , but i can't find an original parts for my Z2
can you tell me where i can buy a genuine original sony remplacment LCd+Digitizer ?
thanks
jean SUNSERI - Réponse
Sony does not sell direct. To get a " genuine " replacement , you have to have the authorized service repair do it. Just buy one off ebay.
Tech Sponge -
Hey!
Thanks for this tutorial. Without this tutorial i would probably done something bad to my phone, but with it everything works!
I had a problem with separating backcover with battery, two screws that holds battery in place in my device didnt hold battery in place, when i pryed open backcover battery instead staying inside her place (inside device) she was glued to backcover and only flex cable was holding it to device. I think that way it was more difficult to separate battery from backcover, so if this happend to you too dont lose hope and have patience. I dont know why it was like that, but when i was closing cover i put effort to check anything was wrong with socket screws etc, but didnt find anything worth mentioning.
kociak0 - Réponse
Please someone help me?
Where do I get the original touch display LCD to buy? For Sony Xperia Z2 D6543 or D6503
Pierre Psy - Réponse
Hi bought LCDs from ebay and they worked well, but one hade weak tape so I neede to replace it. My last LCD I bought for another Z2 was from a repairstore in town.
Claes -
hi, i started disassembling my phone and 1 screw the one in right low side doenst move at all. can u help me guys
Nika Khintibidze - Réponse
Do you have different size screwdrivers? It is sometimes possible to loosen ascrew with the wrong size screwdriver but much easier with the correct one. I think i have used Philips 0 or 00.
Claes -
replacement screen doesn't have Sony logo as pictured above.. installing tomorrow
Cody Viall - Réponse
screen is garbage if you were scared off by all the reviews on amazon it is the same here (ghost touches, screen flickers like a crt tv, colors are washed out) installation was done professionally yet still has touch problems
U got it from ifixit ??
dilip vishwanath -
I have bought two screens from Honkong/Shenzen over e-bay and they where good. The next two I bought from a repairshop in Stockholm also with a good quality.
Claes -
Hey.
My screen is cracked. No damage to the display.Could I only replace the touch screen glass without replacing the display?
Need a reply very soon.....
Rumaiz - Réponse
I have not seen only the glass when I have looked for spare parts.
Claes - Réponse
I also recommend watching the video as well as read the text in this guide. The guide missed out on a lot of details that I saw in the video. Without the video I think I would have been lost. For example "now it's time to test the new spare part". What? The guide doesn't show how to do that! But in the video it's easy to follow along.
It says that this was very hard, but I would say that it's moderate.
Krister - Réponse
Sim is working only for some time after this repair, any solutions pls, I even rebooted+reset to be sure, need help fast,
Avinash Vishnu - Réponse
Excellent thank you
المراكبي - Réponse
Voir les statistiques:
Dernières 24 heures : 14
7 derniers jours : 106
30 derniers jours : 535
Total : 79,611
