Aller au contenu principal
Sony Xperia Z3 Compact Front Camera Replacement
Ce dont vous avez besoin
  1. Sony Xperia Z3 Compact Front Camera Replacement, Front Camera: étape 1, image 1 de 3 Sony Xperia Z3 Compact Front Camera Replacement, Front Camera: étape 1, image 2 de 3 Sony Xperia Z3 Compact Front Camera Replacement, Front Camera: étape 1, image 3 de 3
    • Carefully use a heat gun or hairdryer to melt the adhesive holding the rear case to the phone.
    • Use a suction cup to lift the rear case slightly, enough to slide an opening pick around the edge and loosen the adhesive.
    • Remove back cover.
  2. Sony Xperia Z3 Compact Front Camera Replacement: étape 2, image 1 de 3 Sony Xperia Z3 Compact Front Camera Replacement: étape 2, image 2 de 3 Sony Xperia Z3 Compact Front Camera Replacement: étape 2, image 3 de 3
    • Disconnect the NFC antenna.
    • Unscrew the screws holding the black midframe in place.
    • Remove the midframe.
    • Be aware that there are small tabs holding the midframe into the frame of the phone. These are located at the top and along the sides. You may need pry gently pry the midframe out with the flat end of a spudger.
  3. Sony Xperia Z3 Compact Front Camera Replacement: étape 3, image 1 de 1
    • Disconnect the battery flex cable.
  4. Sony Xperia Z3 Compact Front Camera Replacement: étape 4, image 1 de 3 Sony Xperia Z3 Compact Front Camera Replacement: étape 4, image 2 de 3 Sony Xperia Z3 Compact Front Camera Replacement: étape 4, image 3 de 3
    • Remove bracket.
    • Release connector, but take care not to damage the electronic components next to the connector. It is best to access the connector from the bottom (battery side), and not from the side as the picture shows.
    • Remove rear camera.
  5. Sony Xperia Z3 Compact Front Camera Replacement: étape 5, image 1 de 3 Sony Xperia Z3 Compact Front Camera Replacement: étape 5, image 2 de 3 Sony Xperia Z3 Compact Front Camera Replacement: étape 5, image 3 de 3
    • Release connectors and screw.
  6. Sony Xperia Z3 Compact Front Camera Replacement: étape 6, image 1 de 3 Sony Xperia Z3 Compact Front Camera Replacement: étape 6, image 2 de 3 Sony Xperia Z3 Compact Front Camera Replacement: étape 6, image 3 de 3
    • Remove motherboard.
  7. Sony Xperia Z3 Compact Front Camera Replacement: étape 7, image 1 de 3 Sony Xperia Z3 Compact Front Camera Replacement: étape 7, image 2 de 3 Sony Xperia Z3 Compact Front Camera Replacement: étape 7, image 3 de 3
    • Remove front camera.
3 autres ont terminé cette réparation.
Sophia
Membre depuis le 03/25/14
43 905 Réputation
62 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 7,087
