Introduction
Sony Xperia Z3 battery is non-removable. When you encountered the problem with battery, it's a little complex to replace.
Ce dont vous avez besoin
Vidéo d'introduction
Heat the back cover to soften the adhesive sticker.
Use the suction cup to open a gap from top side or bottom side.
Insert into the guitar pick and slide to cut the sticker.
Remove the back cover.
In step 5 where it says that there is adhesive on the battery, my adhesive was actually joining the battery to the back plate making this step quite difficult. I had to focus the heat on the backplate right where the battery was and then use a long lever to separate the battery from the back plate.
12 autres ont terminé cette réparation.
2 commentaires
Do you happen to know if the Z3 battery will also fit the Z3v i cant seem to find a replacement specifically for the Z3v
Just finished this guide thank you!
