Aller au contenu principal
Sony Xperia Z3 Dual Front Camera Replacement
Ce dont vous avez besoin
  1. Sony Xperia Z3 Dual Front Camera Replacement, Front Camera: étape 1, image 1 de 1
    • Power off the phone and remove two SIM card trays before replacement.
  2. Sony Xperia Z3 Dual Front Camera Replacement: étape 2, image 1 de 3 Sony Xperia Z3 Dual Front Camera Replacement: étape 2, image 2 de 3 Sony Xperia Z3 Dual Front Camera Replacement: étape 2, image 3 de 3
    • Heat to soften back cover adhesive sticker.
    • Use suction cup to open a gap and insert into the guitar pick. Slide the guitar pick to cut the sticker.
  3. Sony Xperia Z3 Dual Front Camera Replacement: étape 3, image 1 de 1
    • Remove back cover carefully and avoid cracking the glass.
  4. Sony Xperia Z3 Dual Front Camera Replacement: étape 4, image 1 de 3 Sony Xperia Z3 Dual Front Camera Replacement: étape 4, image 2 de 3 Sony Xperia Z3 Dual Front Camera Replacement: étape 4, image 3 de 3
    • Remove battery or not is optional. Remove it makes the replacement convenient while keep it also will not block the replacement.
  5. Sony Xperia Z3 Dual Front Camera Replacement: étape 5, image 1 de 1
    • Remove screws at first.
  6. Sony Xperia Z3 Dual Front Camera Replacement: étape 6, image 1 de 3 Sony Xperia Z3 Dual Front Camera Replacement: étape 6, image 2 de 3 Sony Xperia Z3 Dual Front Camera Replacement: étape 6, image 3 de 3
    • Remove three pieces of securing bracket.
  7. Sony Xperia Z3 Dual Front Camera Replacement: étape 7, image 1 de 3 Sony Xperia Z3 Dual Front Camera Replacement: étape 7, image 2 de 3 Sony Xperia Z3 Dual Front Camera Replacement: étape 7, image 3 de 3
    • Release all the connectors connecting with motherboard.
    • Pry the motherboard up from left side and remove it. The motherboard is hold tightly by some hidden keys, so you should be very careful.
  8. Sony Xperia Z3 Dual Front Camera Replacement: étape 8, image 1 de 2 Sony Xperia Z3 Dual Front Camera Replacement: étape 8, image 2 de 2
    • Release the connector and pull out the flex at first, please be careful as you can.
    • Remove the front camera finally.
2 autres ont terminé cette réparation.
Sophia
Membre depuis le 03/25/14
43 810 Réputation
62 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 7
30 derniers jours : 8
Total : 2,341
