Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
This is the replace guide for Sony Xperia Z3 Dual as well as Z3 loudspeaker assembly.
Vidéo d'introduction
  1. Heat to soften back cover sticker. Place the suction cup and try to open a gap. Insert the guitar pick into the gap.
    • Heat to soften back cover sticker.
    • Place the suction cup and try to open a gap.
    • Insert the guitar pick into the gap.
  2. Slide the guitar pick to cut the sticker and remove the back cover. Slide the guitar pick to cut the sticker and remove the back cover.
    • Slide the guitar pick to cut the sticker and remove the back cover.
  3. Remove two screws by Philips screwdriver. Release all the connectors connecting with loudspeaker assembly. Remove the small vibrator securing bracket.
    • Remove two screws by Philips screwdriver.
    • Release all the connectors connecting with loudspeaker assembly.
    • Remove the small vibrator securing bracket.
  4. Remove the securing cover. It's thin and weak, please be careful when remove it. Remove the securing cover. It's thin and weak, please be careful when remove it. Remove the securing cover. It's thin and weak, please be careful when remove it.
    • Remove the securing cover. It's thin and weak, please be careful when remove it.
  5. Pry up the assembly and carry it out. Pry up the assembly and carry it out. Pry up the assembly and carry it out.
    • Pry up the assembly and carry it out.
  6. Remove the loudspeaker assembly finally. Be careful with the flex beside assembly. Remove the loudspeaker assembly finally. Be careful with the flex beside assembly.
    • Remove the loudspeaker assembly finally. Be careful with the flex beside assembly.
4 autre(s) ont terminé cette réparation.
Sophia
Membre depuis le 25/03/2014
43 114 Réputation
62 tutoriels rédigés
this is all good but is there a link to the part ?
morten hundevad - Réponse
EBay search Sony z3 replacement loud speaker cost's around £3-£5
Martin Lb -
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 6
Total : 4,104
