Aller au contenu principal
Sony Xperia Z5 Charging Port Flex Replacement
Ce dont vous avez besoin
  1. Sony Xperia Z5 Charging Port Flex Replacement, Charging Port Flex: étape 1, image 1 de 2 Sony Xperia Z5 Charging Port Flex Replacement, Charging Port Flex: étape 1, image 2 de 2
    • Remove SIM card tray.
  2. Sony Xperia Z5 Charging Port Flex Replacement: étape 2, image 1 de 2 Sony Xperia Z5 Charging Port Flex Replacement: étape 2, image 2 de 2
    • Heat the back cover to soften the adhesive sticker.
    • Place the suction cup and inert metal opening tool to open a gap from top side.
  3. Sony Xperia Z5 Charging Port Flex Replacement: étape 3, image 1 de 3 Sony Xperia Z5 Charging Port Flex Replacement: étape 3, image 2 de 3 Sony Xperia Z5 Charging Port Flex Replacement: étape 3, image 3 de 3
    • Insert the guitar pick and slide it to cut the adhesive sticker underneath.
    • Remove back cover.
  4. Sony Xperia Z5 Charging Port Flex Replacement: étape 4, image 1 de 3 Sony Xperia Z5 Charging Port Flex Replacement: étape 4, image 2 de 3 Sony Xperia Z5 Charging Port Flex Replacement: étape 4, image 3 de 3
    • Release battery connector and pull off the adhesive tape underneath.
    • Pry up battery.
  5. Sony Xperia Z5 Charging Port Flex Replacement: étape 5, image 1 de 3 Sony Xperia Z5 Charging Port Flex Replacement: étape 5, image 2 de 3 Sony Xperia Z5 Charging Port Flex Replacement: étape 5, image 3 de 3
    • Release rear camera connector, front camera connector, audio jack flex connector and main flex connector on the motherboard and remove the screws there.
    • Take away the plastic bracket.
  6. Sony Xperia Z5 Charging Port Flex Replacement: étape 6, image 1 de 3 Sony Xperia Z5 Charging Port Flex Replacement: étape 6, image 2 de 3 Sony Xperia Z5 Charging Port Flex Replacement: étape 6, image 3 de 3
    • Remove metal cover securing loudspeaker and twist off screws.
    • Pry up and loosen the bottom side of main flex assembly.
  7. Sony Xperia Z5 Charging Port Flex Replacement: étape 7, image 1 de 2 Sony Xperia Z5 Charging Port Flex Replacement: étape 7, image 2 de 2
    • Remove main flex. ( Attention: the fingerprint sensor connector is here, be careful to loosen it)
  8. Sony Xperia Z5 Charging Port Flex Replacement: étape 8, image 1 de 2 Sony Xperia Z5 Charging Port Flex Replacement: étape 8, image 2 de 2
    • This is main flex assembly. (It comes with loudspeaker and vibration motor )
  9. Sony Xperia Z5 Charging Port Flex Replacement: étape 9, image 1 de 2 Sony Xperia Z5 Charging Port Flex Replacement: étape 9, image 2 de 2
    • Remove rear camera.
  10. Sony Xperia Z5 Charging Port Flex Replacement: étape 10, image 1 de 3 Sony Xperia Z5 Charging Port Flex Replacement: étape 10, image 2 de 3 Sony Xperia Z5 Charging Port Flex Replacement: étape 10, image 3 de 3
    • Remove that securing bracket, then remove front camera.
  11. Sony Xperia Z5 Charging Port Flex Replacement: étape 11, image 1 de 3 Sony Xperia Z5 Charging Port Flex Replacement: étape 11, image 2 de 3 Sony Xperia Z5 Charging Port Flex Replacement: étape 11, image 3 de 3
    • Release connectors on the motherboard. Remove motherboard.
  12. Sony Xperia Z5 Charging Port Flex Replacement: étape 12, image 1 de 3 Sony Xperia Z5 Charging Port Flex Replacement: étape 12, image 2 de 3 Sony Xperia Z5 Charging Port Flex Replacement: étape 12, image 3 de 3
    • Remove charging port flex.
14 autres ont terminé cette réparation.
Lenka
Membre depuis le 11/06/15
2 384 Réputation
6 tutoriels rédigés
3 commentaires
How about the waterproof adhesive ?
Tess - Réponse
Would you have a step by step method to replace it ?
Tess - Réponse
I can’t turn my phone back on. Any clues?
Bjoern Aeschlimann - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 4
30 derniers jours : 16
Total : 17,558
