Introduction
The motherboard is the central hub of communication between all of the components in the device. If one or more components are failing in your device, you should consider replacing the motherboard. Use this guide to replace the motherboard in your device.
Ce dont vous avez besoin
Remove the motherboard/battery assembly.
Using a spudger, release the battery connector from the motherboard.
