Introduction
Use this guide to replace the screen of the Sony Xperia ZL.
Ce dont vous avez besoin
Open the small cover on the bottom of the rear cover.
Peel back the sticker under the cover to reveal two screws.
Remove the two screws from the back of the phone.
Next pry off the long plastic piece that goes around the perimeter of the left side of the phone. This part contains the volume and power button. The little component where the camera goes will need to be removed. Be careful when removing the front camera components because there is adhesive tape under it.
Next take a small prying tool to separate the glass screen and the frame around the screen. In most procedures the front screen will crack during this step, but luckily our's didn't. It is it okay if the screen cracks, just make sure to pry off all the glass.
A good tip would be to pry into the spots located in the picture.
Once you lift the glass, carefully pry off the adhesive tape around the edges of the phone. Once it has been taken off, carefully remove the screen from the frame and make sure the digitizer that is connected to the screen gets carefully taken out.
The digitizer will be taken out carefully through a small hole at the base of the phone. This needs to be taken out carefully.
3 autres ont terminé cette réparation.
