Introduction
Make sure you can explore the Xplod very well.
Pièces
Aucune pièce nécessaire.
  1. Press down the release button on the bottom left corner of the face plate. Then remove the face plate carefully. Then remove the face plate carefully.
    • Press down the release button on the bottom left corner of the face plate.
    • Then remove the face plate carefully.
  2. %Livraison gratuite pour toute commande supérieure à 100 $US ou contenant un Pro Tech Toolkit !
    Parcourez notre boutique
  3. Use two fingers to create a small gap in the top of the faceplate, as indicated in the picture. Use two fingers to create a small gap in the top of the faceplate, as indicated in the picture. Use two fingers to create a small gap in the top of the faceplate, as indicated in the picture.
    • Use two fingers to create a small gap in the top of the faceplate, as indicated in the picture.
    • Insert the flat end of the Heavy-duty Spudger into the opening you created.
    • Slide it to the right carefully, until you feel the screen pop off.
    • Make sure you keep the face of the screen pointed down as you carefully lift off the freed black portion of the screen - as shown in the picture.
  4. Gently grab the Front Motherboard - as indicated in the picture - and lift it from the rest of the screen. Gently grab the Front Motherboard - as indicated in the picture - and lift it from the rest of the screen.
    • Gently grab the Front Motherboard - as indicated in the picture - and lift it from the rest of the screen.
  5. To remove the LCD, please refer to the iFixit soldering guide.
    • To remove the LCD, please refer to the iFixit soldering guide.
    • Once the LCD screen is removed, you have unrestricted access to the front screen motherboard.
Chao Chen
Membre depuis le 04/10/2011
79 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 5-35, Amido Fall 2011 Membre de l'équipe Cal Poly, Team 5-35, Amido Fall 2011
CPSU-AMIDO-F11S5G35
4 membres
8 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 39
Total : 4,800
