Aller au contenu principal
Sony Xplod CDX-MP30 Front Screen Motherboard Replacement
Ce dont vous avez besoin
  1. Sony Xplod CDX-MP30 Front Screen Motherboard Replacement, Front Panel: étape 1, image 1 de 3 Sony Xplod CDX-MP30 Front Screen Motherboard Replacement, Front Panel: étape 1, image 2 de 3 Sony Xplod CDX-MP30 Front Screen Motherboard Replacement, Front Panel: étape 1, image 3 de 3
    • Press down the release button on the bottom left corner of the face plate.
    • Then remove the face plate carefully.
  2. Sony Xplod CDX-MP30 Front Screen Motherboard Replacement, Front Screen Motherboard: étape 2, image 1 de 1
    Outil utilisé dans cette étape :
    Phillips #0 Screwdriver
    $5.49
    J'achète
  3. Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: étape 3, image 1 de 3 Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: étape 3, image 2 de 3 Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: étape 3, image 3 de 3
    • Use two fingers to create a small gap in the top of the faceplate, as indicated in the picture.
  4. Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: étape 4, image 1 de 3 Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: étape 4, image 2 de 3 Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: étape 4, image 3 de 3
    Heavy-Duty Spudger
    J'achète
    • Insert the flat end of the Heavy-duty Spudger into the opening you created.
    • Slide it to the right carefully, until you feel the screen pop off.
    • Make sure you keep the face of the screen pointed down as you carefully lift off the freed black portion of the screen - as shown in the picture.
  5. Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: étape 5, image 1 de 2 Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: étape 5, image 2 de 2
    • Gently grab the Front Motherboard - as indicated in the picture - and lift it from the rest of the screen.
  6. Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: étape 6, image 1 de 1
    • To remove the LCD, please refer to the iFixit soldering guide.
    • Once the LCD screen is removed, you have unrestricted access to the front screen motherboard.
Chao Chen
Membre depuis le 10/04/11
79 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 5-35, Amido Fall 2011 Membre de l'équipe Cal Poly, Team 5-35, Amido Fall 2011
CPSU-AMIDO-F11S5G35
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 8
Total : 5,601
