Aller au contenu principal
Sony Xplod CDX-MP30 Jammed CD Replacement
Ce dont vous avez besoin
  1. Sony Xplod CDX-MP30 Jammed CD Replacement, Front Panel: étape 1, image 1 de 3 Sony Xplod CDX-MP30 Jammed CD Replacement, Front Panel: étape 1, image 2 de 3 Sony Xplod CDX-MP30 Jammed CD Replacement, Front Panel: étape 1, image 3 de 3
    • Press down the release button on the bottom left corner of the face plate.
    • Then remove the face plate carefully.
  2. Sony Xplod CDX-MP30 Jammed CD Replacement, Main Panels: étape 2, image 1 de 2 Sony Xplod CDX-MP30 Jammed CD Replacement, Main Panels: étape 2, image 2 de 2
    Outil utilisé dans cette étape :
    Phillips #0 Screwdriver
    $5.49
    J'achète
  3. Sony Xplod CDX-MP30 Jammed CD Replacement: étape 3, image 1 de 3 Sony Xplod CDX-MP30 Jammed CD Replacement: étape 3, image 2 de 3 Sony Xplod CDX-MP30 Jammed CD Replacement: étape 3, image 3 de 3
    Phillips #1 Screwdriver
    $5.49
    J'achète
    • Using the Phillips #1 Screwdriver, unscrew the 2 thick screws (length - 7.69mm) located on both sides of the stereo.
    • Remove side-metal plates gently.
    • Use the Heavy-duty Spudger, insert the flat end under each of the black flaps indicated in the picture. Use leverage to pry and pop them loose.
  4. Sony Xplod CDX-MP30 Jammed CD Replacement: étape 4, image 1 de 1
    • Remove the black front plate of the stereo.
  5. Sony Xplod CDX-MP30 Jammed CD Replacement: étape 5, image 1 de 2 Sony Xplod CDX-MP30 Jammed CD Replacement: étape 5, image 2 de 2
    $5.49
    J'achète
    • Using the Phillips #0 Screwdriver, unscrew the 1 gold screw (height - 7.47mm) on the top of the stereo.
    • Lift off the top plate.
  6. Sony Xplod CDX-MP30 Jammed CD Replacement: étape 6, image 1 de 3 Sony Xplod CDX-MP30 Jammed CD Replacement: étape 6, image 2 de 3 Sony Xplod CDX-MP30 Jammed CD Replacement: étape 6, image 3 de 3
    $5.49
    J'achète
    • Using the Phillips #0 Screwdriver, unscrew the 8 gold screws (length - 9.26mm), located on the back side of the stereo.
    • Using the Phillips #0 Screwdriver, unscrew the 2 black screws (length - 13.27mm), also located on the back of the stereo.
    • Using the Phillips #0 Screwdriver, unscrew the 1 gold screw (length - 9.3mm), located on the bottom of a hole as noted in pictures (2) and (3).
  7. Sony Xplod CDX-MP30 Jammed CD Replacement: étape 7, image 1 de 3 Sony Xplod CDX-MP30 Jammed CD Replacement: étape 7, image 2 de 3 Sony Xplod CDX-MP30 Jammed CD Replacement: étape 7, image 3 de 3
    • Carefully pull the fuse out of the back of the stereo.
  8. Sony Xplod CDX-MP30 Jammed CD Replacement: étape 8, image 1 de 2 Sony Xplod CDX-MP30 Jammed CD Replacement: étape 8, image 2 de 2
    • Firmly grip the body of the stereo and pull off the silver back plate.
  9. Sony Xplod CDX-MP30 Jammed CD Replacement: étape 9, image 1 de 1
    $5.49
    J'achète
  10. Sony Xplod CDX-MP30 Jammed CD Replacement: étape 10, image 1 de 2 Sony Xplod CDX-MP30 Jammed CD Replacement: étape 10, image 2 de 2
    $5.49
    J'achète
    • Using the Phillips #0 Screwdriver, unscrew the 2 gold screws (length - 7.34mm) found on both sides of the stereo.
  11. Sony Xplod CDX-MP30 Jammed CD Replacement: étape 11, image 1 de 3 Sony Xplod CDX-MP30 Jammed CD Replacement: étape 11, image 2 de 3 Sony Xplod CDX-MP30 Jammed CD Replacement: étape 11, image 3 de 3
    • Grip the top portion of the stereo, where the CD-Drive is located, and gently pull up to release it, but you will not be able to lift it all the way out.
    • Grab the two tabs located near the back of the stereo, and gently pull the CD-drive front the rest of the device.
  12. Sony Xplod CDX-MP30 Jammed CD Replacement, Jammed CD: étape 12, image 1 de 2 Sony Xplod CDX-MP30 Jammed CD Replacement, Jammed CD: étape 12, image 2 de 2
    $5.49
    J'achète
    • Using the Phillips #0 Screwdriver, unscrew the two gold screws (length - 7.37mm) found on top of the CD Tray.
    • Remove the top cover.
  13. Sony Xplod CDX-MP30 Jammed CD Replacement: étape 13, image 1 de 3 Sony Xplod CDX-MP30 Jammed CD Replacement: étape 13, image 2 de 3 Sony Xplod CDX-MP30 Jammed CD Replacement: étape 13, image 3 de 3
    • These two pieces will NOT separate completely. They are connected by small wires on one side. So make sure you follow the pictures carefully to know which side to pull up.
    • Grip the top of the CD-Drive and pull it up and over, as shown in the pictures.
    • Notice the wires that hold the two pieces together.
  14. Sony Xplod CDX-MP30 Jammed CD Replacement: étape 14, image 1 de 2 Sony Xplod CDX-MP30 Jammed CD Replacement: étape 14, image 2 de 2
    • Pay extra attention to the spring inside the CD-Drive. This will be crucial for the next step.
    • Slowly pull up the side opposite the spring, but make sure not to over-stretch the spring. This could damage the device.
    • While the part is lifted, remove your jammed CD, and you are finished!
Kyle
Membre depuis le 10/10/11
114 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 5-35, Amido Fall 2011 Membre de l'équipe Cal Poly, Team 5-35, Amido Fall 2011
CPSU-AMIDO-F11S5G35
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 4,317
