Aller au contenu principal
SoundBot SB571 Battery Replacement
Ce dont vous avez besoin
  1. SoundBot SB571 Battery Replacement, Battery: étape 1, image 1 de 1
    • Before disassembling the speaker, make sure it is powered off.
    • Place the speaker on a flat surface.
    • Take your blue plastic opening tool and remove the outside cover.
  2. SoundBot SB571 Battery Replacement: étape 2, image 1 de 1
    • Reorient the speaker so the black panel is facing up.
    • Remove the 4, 0.9 cm screws from the back panel using a Phillips PH1 screwdriver.
    • Now remove the plate.
  3. SoundBot SB571 Battery Replacement: étape 3, image 1 de 1
    • Reorient the speaker so the bottom is facing up.
    • Remove the 4, 0.9cm screws from the bottom using a Phillips PH0 screw driver.
    • Now open the plate.
  4. SoundBot SB571 Battery Replacement: étape 4, image 1 de 2 SoundBot SB571 Battery Replacement: étape 4, image 2 de 2
    • With the bottom plate removed now use the blue plastic opening tool to lift up the circuit board from the device.
  5. SoundBot SB571 Battery Replacement: étape 5, image 1 de 2 SoundBot SB571 Battery Replacement: étape 5, image 2 de 2
    • Disconnect the battery wires from the circuit board.
  6. SoundBot SB571 Battery Replacement: étape 6, image 1 de 3 SoundBot SB571 Battery Replacement: étape 6, image 2 de 3 SoundBot SB571 Battery Replacement: étape 6, image 3 de 3
    • Reorient the speaker so the back side is facing up.
    • Now that the battery wires have been disconnected, use a blue plastic tool to release the battery from the adhesive strip.
    • Loop the battery wires through the opening in the back plate.
    • The battery and it's connective wires have been completely removed from the speaker.
11 autres ont terminé cette réparation.
Yana
Membre depuis le 02/09/16
645 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 2-50, Cagle Spring 2016 Membre de l'équipe USF Tampa, Team 2-50, Cagle Spring 2016
USFT-CAGLE-S16S2G50
4 membres
2 tutoriels rédigés
9 commentaires
Please provide the source to buy the replacement battery
Madhu Mohan Bhukya - Réponse
Sir ,m n jully m flipcart se soundbot buy tha jisme kuch dikat aa rhi h bettery ki bajah se
Raj Saini - Réponse
They don't sell batteries!!
international.loop - Réponse
It says above that battery not for sale.
A simple online search and you will find the battery.
Mark Friend - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 19
Total : 8,854
