Aller au contenu principal
SoundBot SB571 Speaker Grille
Ce dont vous avez besoin
  1. SoundBot SB571 Speaker Grille, Speaker Grille: étape 1, image 1 de 1
    • Before disassembling the speaker, make sure it is powered off.
    • Place the speaker on a flat surface.
    • Take your blue plastic opening tool and remove the plastic cover.
  2. SoundBot SB571 Speaker Grille: étape 2, image 1 de 3 SoundBot SB571 Speaker Grille: étape 2, image 2 de 3 SoundBot SB571 Speaker Grille: étape 2, image 3 de 3
    • Orient the speaker so that the top is facing up.
    • Using your Phillips PH0 screwdriver unscrew the 14, 0.6cm screws from the device along the speaker grille.
  3. SoundBot SB571 Speaker Grille: étape 3, image 1 de 2 SoundBot SB571 Speaker Grille: étape 3, image 2 de 2
    • Reorient the speaker so the grille is facing you.
    • Using the blue plastic opening tool, prop open the metal grille.
    • Now the speaker grille is completely removed from the device and it can be replaced.
2 autres ont terminé cette réparation.
Yana
Membre depuis le 02/09/16
645 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 2-50, Cagle Spring 2016 Membre de l'équipe USF Tampa, Team 2-50, Cagle Spring 2016
USFT-CAGLE-S16S2G50
4 membres
2 tutoriels rédigés
Un commentaire
Sir my soundbot sb571 one side sound doesnot work how could i do for its repairing.
Ram Meena - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 4
Total : 1,601
