Aller au contenu principal
Speaker Bose SoundDock Motherboard Replacement
Ce dont vous avez besoin
  1. Speaker Bose SoundDock Motherboard Replacement, Bose SoundDock Motherboard: étape 1, image 1 de 2 Speaker Bose SoundDock Motherboard Replacement, Bose SoundDock Motherboard: étape 1, image 2 de 2
    • Remove the battery by pressing your finger down on the center button and twisting it counter-clockwise.
    • Remove battery and set it aside.
  2. Speaker Bose SoundDock Motherboard Replacement: étape 2, image 1 de 1
    • Use a plastic scraper to remove the rubber gasket from the bottom of speaker system and set it aside.
  3. Speaker Bose SoundDock Motherboard Replacement: étape 3, image 1 de 1
    • Use a standard sized Phillips Screwdriver to remove the four screws on the bottom of the speaker system.
  4. Speaker Bose SoundDock Motherboard Replacement: étape 4, image 1 de 1
    • Using a smaller flat head screw driver, unscrew the semi-circle plate from bottom to expose the motherboard.
    • Once the components are unscrewed, the plastic dock frame may fall out.
  5. Speaker Bose SoundDock Motherboard Replacement: étape 5, image 1 de 1
    • Gently pull both ribbon cables out of the motherboard.
  6. Speaker Bose SoundDock Motherboard Replacement: étape 6, image 1 de 1
    • Replace it with new motherboard by plugging in the thinner wire into the small slot, and the larger wire into the wider slot.
    • Reverse steps 1 through 4 to reassemble dock.
Dalton Alexandre
Membre depuis le 02/24/15
123 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 24-5, Green Winter 2015 Membre de l'équipe Cal Poly, Team 24-5, Green Winter 2015
CPSU-GREEN-W15S24G5
3 membres
4 tutoriels rédigés
Un commentaire
Where can you buy the motherboard?
Steffen Jensen - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 18
Total : 3,276
