Aller au contenu principal
Sphero Ollie Motherboard Replacement
Ce dont vous avez besoin
  1. Sphero Ollie Motherboard Replacement, Tires and Hubcaps: étape 1, image 1 de 1
    • Firmly grasp Ollie in one hand.
    • Remove the blue rubber tire in a peeling motion with your opposite hand.
  2. Sphero Ollie Motherboard Replacement: étape 2, image 1 de 2 Sphero Ollie Motherboard Replacement: étape 2, image 2 de 2
    • Continue to firmly hold Ollie in one hand.
    • Use a Plastic Opening Tool to gently pry off the hubcap.
    • Avoid inserting the Plastic Opening Tool into the empty holes, but instead use the tool near the tabs holding the hubcap in.
    • Do not aim the hubcap towards another person as it may pop off with force.
  3. Sphero Ollie Motherboard Replacement, Motherboard: étape 3, image 1 de 1
    • Loosen and remove the 10mm screw on each side of the device using a JIS 1 screwdriver tip.
    • Remove the plastic tire frame from the device
  4. Sphero Ollie Motherboard Replacement: étape 4, image 1 de 2 Sphero Ollie Motherboard Replacement: étape 4, image 2 de 2
    • Loosen and remove the four 10mm Screws on the underside of the device using a JIS 1 tip.
    • Firmly grasp the bottom of the device and pull the top half of the outer case off of the bottom.
  5. Sphero Ollie Motherboard Replacement: étape 5, image 1 de 2 Sphero Ollie Motherboard Replacement: étape 5, image 2 de 2
    • Loosen and remove the 10mm screws holding the blue tooth connector as well as the two 1 10 screws holding the motherboard to the case using the JIS #1 screwdriver
    • Loosen and remove the 10mm screws holding the antenna to the case.
    • Gently remove mother board from the case with an upward motion.
2 autres ont terminé cette réparation.
Krystal Hedrick
Membre depuis le 10/30/17
364 Réputation
3 tutoriels rédigés
Équipe
UW Tacoma, Team S1-G3, Rose Fall 2017 Membre de l'équipe UW Tacoma, Team S1-G3, Rose Fall 2017
UWT-ROSE-F17S1G3
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 5
Total : 723
