Introduction
If Ollie's wheels are moving slower than you think it should, then you are going to want to change the motors that control the wheels. This guide will walk you through how to replace the motors. All you need is a Phillips #1 Screwdriver and Ollie will be up and running in no time.
Ce dont vous avez besoin
Firmly grasp Ollie in one hand.
Remove the blue rubber tire in a peeling motion with your opposite hand.
Loosen and remove the 10mm screw on each side of the device using a JIS 1 screwdriver tip.
Remove the plastic tire frame from the device
Loosen and remove the 10mm screws holding the blue tooth connector as well as the two 1 10 screws holding the motherboard to the case using the JIS #1 screwdriver
Loosen and remove the 10mm screws holding the antenna to the case.
Gently remove mother board from the case with an upward motion.
After you have removed the motherboard, use a JIS #1 screwdriver to remove the four 10mm screws holding in the cog shields.
Next, you want to pull apart the clips (two on each side) holding the top piece of the shield to the frame.
Then, once you have freed the cogs, you can lift the cog and remove it from the frame.
Then, gently remove the wheels from the case
After you have removed the battery cover, flip the device around to view the motors
Loosen and use a JIS #1 screwdriver to remove the two 10mm Screws holding the clear case of the motors
Next, gently push the clip (on both sides) with a screwdriver to release the clear case
To remove the motors, simply pull on it with slight force
