Aller au contenu principal
Spin Master Hatchimal Draggle Nose Replacement
Ce dont vous avez besoin
  1. Spin Master Hatchimal Draggle Nose Replacement, Plastic Wing Replacement: étape 1, image 1 de 1
    • lay the Hatchimal on its side.
  2. Spin Master Hatchimal Draggle Nose Replacement: étape 2, image 1 de 1
    • Using the plastic opening tool, push in on the purple clip.
  3. Spin Master Hatchimal Draggle Nose Replacement: étape 3, image 1 de 1
    • Pull the wing off of the hatchimal.
    • The wing should come off with little resistance.
  4. Spin Master Hatchimal Draggle Nose Replacement, Fur Replacement: étape 4, image 1 de 2 Spin Master Hatchimal Draggle Nose Replacement, Fur Replacement: étape 4, image 2 de 2
    • Cut the fur retaining zip-tie with a pair of scissors.
  5. Spin Master Hatchimal Draggle Nose Replacement: étape 5, image 1 de 2 Spin Master Hatchimal Draggle Nose Replacement: étape 5, image 2 de 2
    • Lift the fur up until it can't go further.
  6. Spin Master Hatchimal Draggle Nose Replacement: étape 6, image 1 de 3 Spin Master Hatchimal Draggle Nose Replacement: étape 6, image 2 de 3 Spin Master Hatchimal Draggle Nose Replacement: étape 6, image 3 de 3
    • Use the spudger tool to push up on the black clip to free it.
    • Pull the clip out.
  7. Spin Master Hatchimal Draggle Nose Replacement: étape 7, image 1 de 3 Spin Master Hatchimal Draggle Nose Replacement: étape 7, image 2 de 3 Spin Master Hatchimal Draggle Nose Replacement: étape 7, image 3 de 3
    • Lift fur up to reveal the next set of clips.
    • Insert a spudger to push up on the black clip to free it.
    • Pull out the clip.
  8. Spin Master Hatchimal Draggle Nose Replacement: étape 8, image 1 de 2 Spin Master Hatchimal Draggle Nose Replacement: étape 8, image 2 de 2
    • Lift the fur up and over the Hatchimals Head.
    • Remove the six 12mm Phillips #00 screws from then body.
  9. Spin Master Hatchimal Draggle Nose Replacement: étape 9, image 1 de 2 Spin Master Hatchimal Draggle Nose Replacement: étape 9, image 2 de 2
    • Pull the casing apart.
    • Remove the yellow speaker cable.
  10. Spin Master Hatchimal Draggle Nose Replacement: étape 10, image 1 de 3 Spin Master Hatchimal Draggle Nose Replacement: étape 10, image 2 de 3 Spin Master Hatchimal Draggle Nose Replacement: étape 10, image 3 de 3
    • Remove the three 7mm Phillips #00 screws from the head.
    • Remove the wheel base and the circuit board carefully not to damage the spring.
  11. Spin Master Hatchimal Draggle Nose Replacement: étape 11, image 1 de 2 Spin Master Hatchimal Draggle Nose Replacement: étape 11, image 2 de 2
    • Push the six black fur clips out using the spudger.
    • Remove the fur completely.
  12. Spin Master Hatchimal Draggle Nose Replacement, Nose Spring Replacement: étape 12, image 1 de 2 Spin Master Hatchimal Draggle Nose Replacement, Nose Spring Replacement: étape 12, image 2 de 2
    • Using the angled tweezers tool, disconnect the spring that is attached to the nose from the lever.
  13. Spin Master Hatchimal Draggle Nose Replacement: étape 13, image 1 de 1
    • Separate the body casing from the core and circuit board.
    • Don't damage the small wire connected from the top of the head to the circuit board.
  14. Spin Master Hatchimal Draggle Nose Replacement: étape 14, image 1 de 1
    • Remove a single 7mm Phillips #00 screw from the break.
    • Remove the spring.
Hector Lopez
Membre depuis le 02/14/18
251 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team S1-G5, Nance Spring 2018 Membre de l'équipe USF Tampa, Team S1-G5, Nance Spring 2018
USFT-NANCE-S18S1G5
3 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 495
