Aller au contenu principal
Spy Gear Video Walkie Talkies Camera Replacement
Ce dont vous avez besoin
  1. Spy Gear Video Walkie Talkies Camera Replacement, Top Cover: étape 1, image 1 de 1
    • Remove the battery cover by removing the P1 Philips screw.
    • Remove the 3 AA batteries by hand.
  2. Spy Gear Video Walkie Talkies Camera Replacement: étape 2, image 1 de 1
    • Unscrew Top Cover with a 3mm Triangle driver bit from the Driver Kit.
  3. Spy Gear Video Walkie Talkies Camera Replacement: étape 3, image 1 de 1
    • Use Opening Tool to release barbed latch on top cover.
  4. Spy Gear Video Walkie Talkies Camera Replacement: étape 4, image 1 de 1
    • Release pilot studs near the hinge with Metal Spudger.
  5. Spy Gear Video Walkie Talkies Camera Replacement: étape 5, image 1 de 1
    • Once the Top Cover is free, you will have full access to the circuitry.
  6. Spy Gear Video Walkie Talkies Camera Replacement, Camera: étape 6, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Use Tweezers to remove the side button.
  7. Spy Gear Video Walkie Talkies Camera Replacement: étape 7, image 1 de 2 Spy Gear Video Walkie Talkies Camera Replacement: étape 7, image 2 de 2
    • Release the zero insertion force (ZIF) connector.
    • Pull the ribbon cable away carefully.
  8. Spy Gear Video Walkie Talkies Camera Replacement: étape 8, image 1 de 1
    • With the ribbon cable free from obstructions, use a Prying Tool to release the circuit board from the guide studs.
  9. Spy Gear Video Walkie Talkies Camera Replacement: étape 9, image 1 de 1
    • With a plastic Prying Tool, separate the screen from the mounting tray.
    • Adhesive between the layers may provoke damage to the screen or tray. Take your time.
  10. Spy Gear Video Walkie Talkies Camera Replacement: étape 10, image 1 de 1
    • Once the screen is completely folded away from the mounting tray, release it from the circuit board by hand.
  11. Spy Gear Video Walkie Talkies Camera Replacement: étape 11, image 1 de 1
    • Release the back of the mounting tray using a plastic Pick to unhook the barb from the circuit board.
  12. Spy Gear Video Walkie Talkies Camera Replacement: étape 12, image 1 de 1
    • Now remove the mounting tray complete with camera and ribbon cable attached by sliding away from the screen.
    • You must not damage the screen or screen ribbon cable in this step.
  13. Spy Gear Video Walkie Talkies Camera Replacement: étape 13, image 1 de 1
    • Discard faulty camera and mounting tray.
2 autres ont terminé cette réparation.
James French
Membre depuis le 02/15/16
151 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team 7-7, Wilson Spring 2016 Membre de l'équipe IUPUI, Team 7-7, Wilson Spring 2016
IUPUI-WILSON-S16S7G7
5 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 16
Total : 700
