Aller au contenu principal
Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement
Ce dont vous avez besoin
  1. Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Opening the Device: étape 1, image 1 de 2 Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Opening the Device: étape 1, image 2 de 2
    • Remove the six silver 11.4 mm Phillips #0 screws
    • Pry open the device using a plastic opening tool if necessary. To do this, locate the groves running along the side of the entire device and wedge it open.
  2. Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Removing the Styrofoam Pad: étape 2, image 1 de 1
    • Now that your device is open, remove the Styrofoam pad that covers the main circuit board. The adhesive should allow you to remove and replace it with ease.
    • Do this carefully to avoid tearing the pad.
  3. Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Removing the Circuit Board: étape 3, image 1 de 3 Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Removing the Circuit Board: étape 3, image 2 de 3 Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Removing the Circuit Board: étape 3, image 3 de 3
    • Remove the eight black 7.2 mm Phillips #0 screws from the top of the circuit board and remove the circuit board.
  4. Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Removing The Micro SD Reader: étape 4, image 1 de 3 Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Removing The Micro SD Reader: étape 4, image 2 de 3 Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Removing The Micro SD Reader: étape 4, image 3 de 3
    • Unscrew the one 7.2 mm Phillips #0 screw from the plastic piece covering the microSD reader.
    • Then, unscrew the two 7.2 mm Phillips #0 screws from the microSD reader and remove it from its fastening.
  5. Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Un-Soldering the Wires: étape 5, image 1 de 1
    • On the back side of the reader there are nine wires. Un-solder these wires, remove the micro SD card reader, and solder on the replacement.
    • Need Help Soldering? Check out Comment souder et dessouder des connexions for tips.
Andrew Gittens
Membre depuis le 09/22/14
143 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 4-5, Brown Fall 2014 Membre de l'équipe USF Tampa, Team 4-5, Brown Fall 2014
USFT-BROWN-F14S4G5
3 membres
6 tutoriels rédigés
1 commentaire de tutoriel
Where do you get the replacement parts?
clsutliff - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 15
Total : 576
