Aller au contenu principal
Squier Strat Guitar Pickups Replacement
Ce dont vous avez besoin
  1. Squier Strat Guitar Pickups Replacement, Pickups: étape 1, image 1 de 3 Squier Strat Guitar Pickups Replacement, Pickups: étape 1, image 2 de 3 Squier Strat Guitar Pickups Replacement, Pickups: étape 1, image 3 de 3
    • Unwind the strings by turning the tuning pegs.
    • Pull the strings out of the tuning peg holes.
    • Push the strings out through the back plate holes.
    • Use a string winder to speed up this process.
  2. Squier Strat Guitar Pickups Replacement: étape 2, image 1 de 2 Squier Strat Guitar Pickups Replacement: étape 2, image 2 de 2
    • Remove the 11 screws holding the pickguard to the body of the guitar.
  3. Squier Strat Guitar Pickups Replacement: étape 3, image 1 de 3 Squier Strat Guitar Pickups Replacement: étape 3, image 2 de 3 Squier Strat Guitar Pickups Replacement: étape 3, image 3 de 3
    • Lift up the pickup guard gently.
    • Flip the pickup guard to expose the wiring.
    • Place a towel underneath the pickup guard to protect your guitar's body.
    • Potential for device damage: Do not use excessive force when lifting the pickup guard.
  4. Squier Strat Guitar Pickups Replacement: étape 4, image 1 de 2 Squier Strat Guitar Pickups Replacement: étape 4, image 2 de 2
    • Take note of where each pickup is wired.
    • Make sure to keep track of the negative and positive wires. Black wires usually indicate negative wires.
    • Pickups are usually wired to the potentiometers and pickup selector switch.
  5. Squier Strat Guitar Pickups Replacement: étape 5, image 1 de 2 Squier Strat Guitar Pickups Replacement: étape 5, image 2 de 2
    • Desolder the pickups from the pickup selector switch using a quality soldering iron and soldering wick.
    • Desolder the pickups from the potentiometers.
    • Potential for device damage: Excessive heat from the soldering iron can damage components.
  6. Squier Strat Guitar Pickups Replacement: étape 6, image 1 de 2 Squier Strat Guitar Pickups Replacement: étape 6, image 2 de 2
    • Flip the pickup guard back to its original position.
    • Remove the screws holding the pickups to the pickup guard.
  7. Squier Strat Guitar Pickups Replacement: étape 7, image 1 de 2 Squier Strat Guitar Pickups Replacement: étape 7, image 2 de 2
    • Flip the pickup guard to reveal the wiring.
    • Remove the pickups from the pickup guard. They should come out very easily.
4 autres ont terminé cette réparation.
Ion
Membre depuis le 09/29/15
479 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 10-5, Green Fall 2015 Membre de l'équipe Cal Poly, Team 10-5, Green Fall 2015
CPSU-GREEN-F15S10G5
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 15
30 derniers jours : 35
Total : 7,487
