Aller au contenu principal
Stapler Maintenance
  1. Stapler Maintenance, Open & Identify: étape 1, image 1 de 2 Stapler Maintenance, Open & Identify: étape 1, image 2 de 2
    • Be careful while handling staples or any sharp object in general.
    • Grab the base of the stabler, and pull the hammer until the stapler opens, revealing the carrier, pusher, and spring.
    • Identify the staple type by looking on the bottom of the carrier. If the staple type is not on the carrier, look under the base.
  2. Stapler Maintenance, Insert Staples: étape 2, image 1 de 2 Stapler Maintenance, Insert Staples: étape 2, image 2 de 2
    • Get a cluster of staples and carefully place it in the carrier.
    • Make sure there is enough room for the pusher to contact the staples.
    • Close the stapler by clearing your hand from under the crimp area and pushing the hammer down until a clicking sound is heard.
  3. Stapler Maintenance: étape 3, image 1 de 1
    • Don’t staple your hand, or anyone else for that matter.
    • Congratulations! You have successfully replaced staples in your stapler.
7 autres ont terminé cette réparation.
Sequoia Equities
Membre depuis le 01/22/15
225 Réputation
1 tutoriel rédigé
Un commentaire
Wnen I tried to load the staples, the spring came loose. But I do not know where to reconnect it and have a loose short plastic rod!
Brian Gray - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 17
7 derniers jours : 123
30 derniers jours : 543
Total : 14,336
