Aller au contenu principal
Starbucks Barista Pump Replacement
Ce dont vous avez besoin
  1. Starbucks Barista Pump Replacement, Pump: étape 1, image 1 de 3 Starbucks Barista Pump Replacement, Pump: étape 1, image 2 de 3 Starbucks Barista Pump Replacement, Pump: étape 1, image 3 de 3
    • First remove all six screws on the back panel.
    • Remove the back panel, then set it aside.
    • Remove the two screws holding the bottom panel in place.
    • Remove the bottom panel, then set it aside.
  2. Starbucks Barista Pump Replacement: étape 2, image 1 de 3 Starbucks Barista Pump Replacement: étape 2, image 2 de 3 Starbucks Barista Pump Replacement: étape 2, image 3 de 3
    • Pull the drip tray out, then set it aside.
    • Turn the brew unit clockwise to unscrew.
    • Pull the tube that goes into water reservoir out.
    • Slide the water reservoir out through the front of the barista to remove it.
    • Remove the top tray from the backside.
  3. Starbucks Barista Pump Replacement: étape 3, image 1 de 3 Starbucks Barista Pump Replacement: étape 3, image 2 de 3 Starbucks Barista Pump Replacement: étape 3, image 3 de 3
    • Use an adjustable wrench to unscrew the connection tube between the pump and the boiler.
    • Pull off both tubes connecting on each side of the pump.
    • Remove the 3 electrical connectors from the pump.
  4. Starbucks Barista Pump Replacement: étape 4, image 1 de 3 Starbucks Barista Pump Replacement: étape 4, image 2 de 3 Starbucks Barista Pump Replacement: étape 4, image 3 de 3
    • Unscrew the two mounting bolts.
    • Remove the pump unit from the Barista.
    • Pull off the yellow end of the pump and unscrew T-shaped end.
    • See the links section of the device page for where to purchase a new pump.
16 autres ont terminé cette réparation.
Alex
Membre depuis le 01/28/11
511 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 4-42, Regan Winter 2011 Membre de l'équipe Cal Poly, Team 4-42, Regan Winter 2011
CPSU-REGAN-W11S4G42
4 membres
10 tutoriels rédigés
22 commentaires
What is meant by "See the links section of the device page for where to purchase a new pump"? Which device page on which website? Are you not able to just post the link? Which type/model of pump is required?
nick - Réponse
My son and I successfully replaced the pump, but it didn't go quite as easily as I'd thought. We could not get the hose that connects the boiler to the pump off. Thankfully, my clever son realized we could turn the portion of the pump that screws into the t-end to get the old pump off and new one on.....tricky, but doable. The new pump is a bit noisier than the last, but she pulls beautiful shots. Thanks so much for this guide!
Bananaslug - Réponse
I put in a new pump and it still doesn’t work. I hear it him but can’t get it to pull water. I’ve tried the water in the line thing. How is the best way to prime it? Maybe that’s it?
wendy.tracy007 -
Wendy
Open the steam valve, so there is no back pressure inside the boiler preventing the pump from pulling water.
Gary Naka -
Thanks for this tip.
I had the same problem, could not get the tefflon tube out of the brass T/OPV.
Rotated the pump off the T/OPV.
Gary Naka -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 19
30 derniers jours : 71
Total : 37,314
