Aller au contenu principal
Starbucks Barista Ready Light Replacement
Ce dont vous avez besoin
  1. Starbucks Barista Ready Light Replacement, Ready Light: étape 1, image 1 de 2 Starbucks Barista Ready Light Replacement, Ready Light: étape 1, image 2 de 2
    • Unscrew the 6 screws from the back panel.
    • Remove the back panel.
  2. Starbucks Barista Ready Light Replacement: étape 2, image 1 de 3 Starbucks Barista Ready Light Replacement: étape 2, image 2 de 3 Starbucks Barista Ready Light Replacement: étape 2, image 3 de 3
    • Locate the ready light.
    • Gently push the fixture against the Barista wall.
    • Pull the fixture straight up to release it.
    • Note: The fixture works as a spring.
    • Note: The green cover from the front panel will "pop" off. Do not lose the green cover.
    • Disconnect the wire lead connectors.
    • Remove the ready light unit (fixture).
  3. Starbucks Barista Ready Light Replacement: étape 3, image 1 de 1
    • Replace the old LED with a new LED.
    • To put back, match the green cover to the slot of the LED fixture, then slide the fixture down against the barista wall.
David
Membre depuis le 01/28/11
748 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 4-42, Regan Winter 2011 Membre de l'équipe Cal Poly, Team 4-42, Regan Winter 2011
CPSU-REGAN-W11S4G42
4 membres
5 tutoriels rédigés
4 commentaires
Youth and sports for
Rich Ridout - Réponse
Ttuii addinsists
Where can I get a new LED bulb?
Paula - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 5
30 derniers jours : 18
Total : 6,134
