Aller au contenu principal
Introduction
The steam wand is used to steam and froth milk as well as dispense hot water for Americanos or tea.
Outils
Pièces
Aucune pièce spécifiée.
  1. Using a wrench, unscrew the hex nut and remove the steam wand.
    • Using a wrench, unscrew the hex nut and remove the steam wand.
    • Note: Do not lose the hex nut once it is unscrewed.
  2. Using a thin tool or item, such as a paper clip, poke around through the holes on both ends of the wand to remove any foreign material. Place the steam wand in a de-calcifying solution as directed by product.
    • Using a thin tool or item, such as a paper clip, poke around through the holes on both ends of the wand to remove any foreign material.
    • Place the steam wand in a de-calcifying solution as directed by product.
    • Reconnect the steam wand.
    • See the links section of the device page to purchase a new steam wand.
4 autres ont terminé cette réparation.
David
Membre depuis le 28/01/2011
697 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 4-42, Regan Winter 2011 Membre de l'équipe Cal Poly, Team 4-42, Regan Winter 2011
CPSU-REGAN-W11S4G42
4 membres
5 tutoriels rédigés
To replace steam-wand seals (in case of water leaking out from the center of the steam-wand): https://www.youtube.com/watch?v=fulyy9A9... , but note - for parts: https://philips.encompass.com/model/SAER... (worth going to amazon.de and entering the partnumbers into the search box: e.g. the o-rings for the needle-valve (996530013462)
R Cly - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 13
30 derniers jours : 58
Total : 14,502
