Introduction
Brand: KitchenAid Stove
Purpose of this guide: Replace a Stove Element Receptacle.
This guide will demonstrate how to replace a broken element receptacle in a stove. Make sure to disconnect your power supply before beginning.
Ce dont vous avez besoin
First, locate the the gas safety shut-off valve and turn off the power supply.
Remove the pitted scorched burner.
Remove the drip tray after removing the pitted scorched burner.
Pull the old receptacle block out and cut the receptacle block.
To strip the wires, place about an inch from the end of the wire into the mouth of the wire stripper. Carefully cut through the insulation without cutting through the copper wire.
With the mouth of the wire strippers still closed, pull the sheathing off to the end of the wire.
2 autres ont terminé cette réparation.
