Aller au contenu principal
Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement
  1. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement, Top Floater Removal: étape 1, image 1 de 1
    • Remove the black screw by rotating it counterclockwise.
  2. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement: étape 2, image 1 de 1
    • Hold the device in place and pull up on the floater.
  3. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement: étape 3, image 1 de 1
    • Remove the top floater.
  4. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement, Battery: étape 4, image 1 de 1
    • Turn the device upside-down.
  5. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement: étape 5, image 1 de 1
    • Press the push button in while sliding the planner towards the back of the device to remove the battery panel.
  6. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement: étape 6, image 1 de 1
    • A push tab holds the battery in.
  7. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement: étape 7, image 1 de 1
    • Push the tab in and pull the battery outward to remove it.
  8. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement, Lower Panel: étape 8, image 1 de 1
    • Remove the ten Phillips screws on the bottom of the device. Remove the bottom panel.
  9. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement: étape 9, image 1 de 1
    • Pull the panel forward.
    • You may need to use pry tools to aid in separating the panels.
  10. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement, Activation Buttons: étape 10, image 1 de 1
    • There are two action buttons on each side of the main body.
  11. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement: étape 11, image 1 de 1
    • Push on the top outer corner of each action button to pop them out of place.
  12. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement: étape 12, image 1 de 1
    • After each action button is released, pull outward to remove.
Benjamin J Farland
Membre depuis le 10/30/23
271 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 2-6, Gulbrandsen Fall 2023 Membre de l'équipe UMass Dartmouth, Team 2-6, Gulbrandsen Fall 2023
UMASSD-GULBRANDSEN-F23S2G6
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 20
Total : 81
