Introduction
This guide will show you hot to replate the safety switch on the Sublue WhiteShark Mix Underwater Scooter.
Remove the ten Phillips screws on the bottom of the device. Remove the bottom panel.
Place the main body panel with the handle that holds the safety switch towards you. Pull the white tab of the right and pull towards you from the top of the safety switch.
Presque terminé !
