Introduction
This is a guide to help you safely teardown your Super Mario Bros. 35th anniversary Game and Watch! (This guide is not professionally made! This means there may be a better way to do a step!)
Ce dont vous avez besoin
For the smaller ribbon cable (Backlight ribbon), Lift the small black bar upwards lightly with your nail or a small flathead bit.
With either a small flathead or spudger, pry up the black bar on the wide ribbon cable.
Using a small flathead, Pry upwards from the top right of the speaker.
Remove the 1 screw in the top right (this is the last screw on the system) and lift up the housing.
You should be able to lift out the buttons.
Congrats! You made it to the end! Just follow the steps in reverse to rebuild the unit.
