Aller au contenu principal
Remplacement du port du contrôleur du Super Nintendo
Ce dont vous avez besoin
  1. Remplacement du port du contrôleur du Super Nintendo, Boitier externe: étape 1, image 1 de 1
    • Retirez les six vis situées sous le système à l'aide du tournevis Gamebit 4,5 mm.
    In order to prevent damage to the fuse, make sure that you always cycle the power before doing so with the power supply disconnected.
    Raucedine - Réponse
    There is a step missing from these instructions. There are two philips head screws where the AV/Power ports are on the back of the motherboard that need to be removed before you can remove the motherboard itself.
    phoenixknight8082 - Réponse
    I replaced my controller port, thinking that it was the culprit, but my SNES is still having issues. Nothing works for controller port 1 and only a few buttons work for controller port 2. I tried switching out the controllers and the issue seems to be isolated to the SNES itself. Does anyone have any other suggestions for fixing my issue?
    Thanks in advance.
    Mike Watts - Réponse
    For those facing a black screen on startup (after having cleaned pins on cartridges and cartridge slot) WITH power light coming on, turn off console, remove power, and try shorting out the capacitor leads. My SNES stopped working suddenly after a single power cycle, and shorting out the leads (while UNPOWERED) revived it.
    Austin Barnett - Réponse
    Could you further explain how to short the capacitor leads?
    Will Pulman -
  2. Remplacement du port du contrôleur du Super Nintendo: étape 2, image 1 de 3 Remplacement du port du contrôleur du Super Nintendo: étape 2, image 2 de 3 Remplacement du port du contrôleur du Super Nintendo: étape 2, image 3 de 3
    • Retournez soigneusement l'appareil.
    • Localisez la couture. Soulevez et séparez la moitié supérieure du boîtier de la moitié inférieure du boîtier.
  3. Remplacement du port du contrôleur du Super Nintendo, Bouton d'éjection: étape 3, image 1 de 2 Remplacement du port du contrôleur du Super Nintendo, Bouton d'éjection: étape 3, image 2 de 2
    • Soulevez le côté droit du levier d'éjection hors du boîtier.
  4. Remplacement du port du contrôleur du Super Nintendo: étape 4, image 1 de 3 Remplacement du port du contrôleur du Super Nintendo: étape 4, image 2 de 3 Remplacement du port du contrôleur du Super Nintendo: étape 4, image 3 de 3
    • Tirez la barre métallique à travers le côté droit du levier d'éjection.
    • Assurez-vous de garder une trace du ressort situé sur le côté gauche du levier car il peut jaillir lors du retrait de la barre métallique.
    • Au remontage, la procédure devient plus difficile à cause du ressort (marqué en rouge). Nous recommandons qu'une personne maintienne le ressort en place (photo 3) tandis qu'une autre personne glisse la barre métallique dans le boîtier de gauche et glisse le levier d'éjection sur la barre métallique.
  5. Remplacement du port du contrôleur du Super Nintendo, Port du contrôleur: étape 5, image 1 de 1
    • Soulevez les ports du contrôleur hors du boîtier, cela doit être fait sans trop de force. Notez l'emplacement de la connexion du câble plat.
  6. Remplacement du port du contrôleur du Super Nintendo: étape 6, image 1 de 2 Remplacement du port du contrôleur du Super Nintendo: étape 6, image 2 de 2
    • Retirez délicatement le câble plat de son port.
Pour remonter votre appareil, suivez ces instructions dans l'ordre inverse.
17 autres ont terminé cette réparation.
Merci à ces traducteurs :
en fr
100%
[deleted] nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
James Shirley
Membre depuis le 10/03/10
967 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 4-47, Amido Fall 2010 Membre de l'équipe Cal Poly, Team 4-47, Amido Fall 2010
CPSU-AMIDO-F10S4G47
4 membres
25 tutoriels rédigés
2 commentaires
I did a complete teardown of my 26 year old super Nintendo because I had to fix the AV jack. the hardest part was the de soldering. however upon putting it back together I could get the games to play, however it was in black and white…or even a grayish hue…and the controllers didn't work. shortly after the ribbon connecting the controller input to the system snapped on one end. do you think this was the issue, and where do I find a new one? Thanks.
Keith Goetting - Réponse
This isn’t complete. How about taking the face plate off?
Daniel Powers - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 27
30 derniers jours : 126
Total : 33,369
