Aller au contenu principal
Surface Laptop Studio Headphone Jack Replacement
Ce dont vous avez besoin
  1. Surface Laptop Studio Headphone Jack Replacement, Lower Case: étape 1, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Remove the rubber cosmetic strip along the outside edge of the back plate with tweezers.
  2. Surface Laptop Studio Headphone Jack Replacement: étape 2, image 1 de 2 Surface Laptop Studio Headphone Jack Replacement: étape 2, image 2 de 2
    • Remove the two rubber feet on the lower case with an opening tool.
  3. Surface Laptop Studio Headphone Jack Replacement: étape 3, image 1 de 1
    • Remove the two screws with a T3 Torx screwdriver.
  4. Surface Laptop Studio Headphone Jack Replacement: étape 4, image 1 de 1
    • Remove the seven screws securing the lower case with a T3 Torx screwdriver.
  5. Surface Laptop Studio Headphone Jack Replacement: étape 5, image 1 de 2 Surface Laptop Studio Headphone Jack Replacement: étape 5, image 2 de 2
    • Lift the lower case gently and set it above the device.
    • Take care not to strain the battery cable as you move the lower case.
  6. Surface Laptop Studio Headphone Jack Replacement, Surface Laptop Studio Battery Disconnection: étape 6, image 1 de 2 Surface Laptop Studio Headphone Jack Replacement, Surface Laptop Studio Battery Disconnection: étape 6, image 2 de 2
    • Disconnect the battery cable by lifting the pull tab until it "clicks."
  7. Surface Laptop Studio Headphone Jack Replacement, Headphone Jack: étape 7, image 1 de 3 Surface Laptop Studio Headphone Jack Replacement, Headphone Jack: étape 7, image 2 de 3 Surface Laptop Studio Headphone Jack Replacement, Headphone Jack: étape 7, image 3 de 3
    • Remove the left I/O bracket by unscrewing the the 3 M1109237 Screws with your T3 Torx screwdriver.
  8. Surface Laptop Studio Headphone Jack Replacement: étape 8, image 1 de 1
    • Remove the two M1168360 screws on the headphone jack with your T3 Torx screwdriver.
  9. Surface Laptop Studio Headphone Jack Replacement: étape 9, image 1 de 1
    • Flip up the headphone jack's ZIF connector locking flap.
    • Remove the ribbon cable from the port.
  10. Surface Laptop Studio Headphone Jack Replacement: étape 10, image 1 de 1
    J'achète
    • Lift the headphone jack up and out with your tweezers.
Nate Ball
Membre depuis le 02/14/23
669 Réputation
5 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 18
Total : 194
